Pcv valve & o2 Sensor 94 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 10 Old 01-04-2005, 02:56 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Pcv valve & o2 Sensor 94 Camry V6 3000 cam
Hi guys 2 questions im tring to replace this parts just dont know where they are...pictures will be very nice THANKS ALL....
1)where can i find the pcv valve
2)where can i find the o2 sensor
1994 Toyota Camry XLE V6 3000 Cam
1992 Honda Civic LX 1.6L
GodofRage is offline
post #2 of 10 Old 01-04-2005, 03:12 AM
VeeZed
JetspeedCamry's Avatar
Quoted: 0 Post(s)
What motor?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline
post #3 of 10 Old 01-04-2005, 04:24 AM
Banned by a newb
Quoted: 0 Post(s)
Cool
1mz-fe v6, or 5s-fe i4?
Either way there are two larger black hoses on the passanger side of the upper intake air chamber (highest part of the engine).
One goes to a metal pipe on the firewall that goes to your brake booster (big circular thing your brake cylinder sits on{the thing that holds the brake fluid})
The other one that goes maybe 8-10 inchest to the valve cover of the motor is the PCV hose.
The PCV valve is normally a little white plastic thing that either snaps out when you pull realy hard, or brakes. It's like a $5 part.
If it's an I4 the o2 sensor is on the exhaust manifold staring you in the face.
If it's a v6 you have one on each exaust manifold (front like the i4, and one in the back, on the rear manifold) and if you have a California emessions car, one after the catalitic convertor.
May I ask, why do you want to know where the PCV valve, and o2 sensor<s> are?
Toysrme is offline
post #4 of 10 Old 01-04-2005, 12:41 PM
Grenaded piston
88 LE's Avatar
Quoted: 3 Post(s)
88 LE is offline
post #5 of 10 Old 01-04-2005, 02:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks for your feed backs but how do i know which 02 sensor should i replace thats most important? Bank 2 sensor 1, Bank 1 Sensor 1, bank 1 Sensor 2
post #6 of 10 Old 01-04-2005, 05:32 PM
tC
Quoted: 0 Post(s)
do a search on o2 sensors. i recently asked the same question. i got some mixed answers at first but i think it was clearified by the end of the post. a haynes manual would also tell you exactly which sensor is which. b1 s1, or b2 s1 etc. there is a great picture in the haynes. search "o2 sensor" in this forum youll get the answers you need.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline
post #7 of 10 Old 01-04-2005, 05:48 PM
JUST RE ENGINEER IT
fredk's Avatar
Quoted: 0 Post(s)
OK, you have 3 o2 sensors evidently, and the puzzle goes like this bank 1 is the bank with #1 cylinder in it usually and sensor 1 is in the manifold and sensor 2 is in the pipe, so b1s1 is in the manifold of the side of the motor with #1 cylinder in it and b2s1 is the sensor in the other manifold, now each bank may have its own downstream o2 or the car may have just 1 downstream just past the last cat in the y pipe, this is b1s2 or b2s2
fredk is offline
post #8 of 10 Old 01-04-2005, 05:54 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I just went to AutoZone and they are asking alot of money for bosch 02 sensor for around $147 O.E. ouch anyone know where i get them cheaper?
post #9 of 10 Old 01-04-2005, 06:11 PM
tC
Quoted: 0 Post(s)
http://www..com/
^^has them for $99.15. cheapest ur gonna get unless you buy a universal one and splice the connector on yourself. i hear the bosch ones come with a pretty nifty splicing kit. ive never used it myself but its an option.(much cheaper!!!)
make sure you figure out which sensor you need so you dont spend more than you have to.
also, i checked my haynes and there is a perfect diagram on page 6-5 that shows which sensor is which.
07 tC MT
-TRD RSB
-TRD Exhaust
95camguy is offline
post #10 of 10 Old 01-04-2005, 06:39 PM
JUST RE ENGINEER IT
fredk's Avatar
Quoted: 0 Post(s)
NEVER get an o2 that you have to cut the wires
fredk is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
