INFO: 1996 Toyota Camry Specifications - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 23 Old 03-07-2005, 06:18 PM Thread Starter
it was all a dream
Quoted: 0 Post(s)
(Thread Starter)
Post INFO: 1996 Toyota Camry Specifications
1996 TOYOTA CAMRY SPECIFICATIONS
CAMRY FOUR-CYLINDER
ENGINE
2.2 liter 4-cylinder in-line twin cam
16-valve multi-point EFI, cast iron block with
aluminum alloy head
Bore & stroke 3.43 x 3.58 in
Displacement 2.2L/2164cc
Compression ratio 9.5:1
Valve train Twin-cam, 4-valve/cyl
HP (SAE Net) 125 HP @ 5400 RPM
Torque 145 lb ft @ 4400 RPM
Ignition system Electronic
Fuel system Multi-point EFI
Recommended fuel 87 Octane
POWERTRAIN
Drive system type: Transaxle/Front-wheel drive
5-SPEED MANUAL
Ratios
1st......... 3.538
2nd......... 1.960
3rd......... 1.250
4th......... 0.945
5th......... 0.731
Reverse..... 3.153
Differential Ratio 3.944
4-SPEED ECT AUTOMATIC
Ratios
1st......... 2.810
2nd......... 1.549
3rd......... 1.000
4th......... 0.706
Reverse..... 2.296
Differential Ratio 3.731
CAMRY V6
ENGINE
3.0 liter 6-cylinder vee-type four cam
24-valve multi-point EFI, aluminum block
with aluminum alloy heads
Bore & stroke 3.44 x 3.27 in
Displacement 3.0L/2995cc
Compression ratio 10.5:1
HP (SAE Net) 188 HP @ 5200 RPM
Torque 203 lb ft @ 4400 RPM
Recommended fuel 91 Octane
POWERTRAIN
Drive system type Transaxle/Front-wheel drive
5-SPEED MANUAL N/A
4-SPEED ECTi AUTOMATIC
Ratios 1st......... 2.810
2nd......... 1.549
3rd......... 1.000
4th......... 0.735
Reverse..... 2.296
Differential Ratio 3.426
(3.717 SE)
CAMRY FOUR-CYLINDER
SUSPENSION
Front Independent MacPherson strut with
stabilizer bar, gas-filled
shocks and anti-vibration sub-frame
Rear Ind. dual link with gas-filled
shocks, stabilizer bar and
anti-vibration sub frame
Stabilizer bar diameter
Front............... 0.94 in
Rear ............... 0.67 in
BRAKES
Front Ventilated disc 10.0 in
Front swept area 189 sq in
Rear w/o ABS Drum 9.0 in
w/ABS Solid disc 10.6 in
Rear swept area
w/o ABS 78 sq in
w/ABS 159 sq in
Parking Center hand brake
ABS Optional (Standard on XLE)
STEERING
Type Power-assist rack and pinion
Ratio 17.4:1
St. whl turns (lock to lock) 3.06
Turning circle (ft) 35.4
CAPACITIES
Engine oil 4.0 qts
Cooling system 6.7 qts
Fuel tank 18.5 gal
CAMRY V6
SUSPENSION
Front............... 0.90 in
Rear ............... 0.59 in (0.67 in - SE)
BRAKES
Front Ventilated disc 10.7 in
Front swept area 227 sq in
Rear Disc 11.3 in
Rear swept area 174 sq in
Parking Footbrake
Center handbrake (SE)
ABS Optional (standard on XLE)STEERING
Ratio 17.4:1 (SE: 15.9:1)
Turning circle (ft) 36.7
CAPACITIES
Engine oil 4.3 qts
Cooling system 9.8 qts
Fuel tank 18.5 gal
CAMRY FOUR-CYLINDER
TIRES & WHEELS
Wheel size 5.5 x 14 in
Type & material Steel (DX, LE)
Aluminum alloy (XLE)
Tire Size 195/70HR14
Tire type All-season steel radials
Spare tire Full size
Wagon temporary spare w/ 3rd seat
SAFETY SPECIFICS
--Dual air bags standard
--3-pt front shoulder belts w/adjustable
shoulder anchors (sedan/wgn only)
--3-pt rear outboard shoulder belts,
center lap belt
--Dynamic side door impact beams (sdn/wgn/coupe)
--ALR/ELR function on front passenger
and rear outboard seatbelts
--3-pt outboard shoulder belts w/wagon third seat
--Child-protector rear door locks (sdn/wgn)
--High-tensile strength steel engine hood, door
panels and frame members
--Front and rear crumple zones
BASIC LIMITED WARRANTY COVERAGE
1 yr/12,500 mi. service adjustments
3 yr/36,000 mi. comprehensive
5 yr/60,000 powertrain
5 yr corrosion perforation
BODY DESIGN & MATERIALS
Unitized steel body and unitized frame
CAMRY V6
TIRES & WHEELS
Wheel size 6.0 x 15 in
Type & material Steel (LE)
Aluminum alloy (XLE, SE)
Tire Size 205/65HR15 (LE, XLE)
205/65VR15 (SE)
Tire type
All-season steel radials (LE, XLE)
V-rated steel radials (SE)
SAFETY SPECIFICS
Same as four-cyinder
CAMRY FOUR-CYLINDER
EXTERIOR DIMENSIONS (inches)
Wheelbase 103.1
Overall length Wagon 189.4, 187.8
Overall width 69.7
Overall height Sedan 55.9
Coupe 55.5
4-cyl. wagon 57.1
Front track 61.0
Rear track 59.0
Wagon 59.1
Min ground clearance 5.7
INTERIOR DIMENSIONS (inches)
Headroom (f/r) Sedan 38.4/37.1
Coupe 38.4/37.4
Wagon 39.2/38.8
3rd seat 30.4
Legroom Front 43.5
Sedan rear 35.0
Coupe rear 33.0
Wagon rear 34.7
Wagon 3rd seat 28.0
Shoulder Rm (f/r) Sedan 56.8/56.1
Coupe 56.5/55.2
Wagon 56.8/56.0
Wagon 3rd seat 47.4
EPA volume (cu ft) Sedan 112.1
Coupe 108.9
Wagon 140.8
EPA class Mid-size
Cargo volume (cu ft)
Sedan, coupe 14.8
Behind 2nd seat 40.5
Wag. 2nd and 3rd seat folded 74.8
CAMRY V6
Wheelbase 103.1
Overall width 69.7
Coupe 55.5
V6 wagon 57.3
Front track 61.0
Rear track 59.0
Wagon 59.1
V6 wagon 5.9
Same as four-cylinder
CAMRY FOUR-CYLINDER
VEHICLE MASS (lb)
Curb weight Sedan DX 5M 2932
DX 4ECT 2976
LE 4ECT 3086
XLE 4ECT 3131
Wagon LE 4ECT 3263
Coupe DX 5M 2910
DX 4ECT 2954
LE 4ECT 3064
Max trailer weight 2000
PRELIM. EPA EST. FUEL ECONOMY
City/Hwy
5M 23/31
4ECT 21/28
CAMRY V6
VEHICLE MASS (lb)
Curb weight Sedan LE 4ECTi 3241
XLE 4ECTi 3274
SE 4ECTi 3186
Wagon LE 4ECTi 3406
Coupe LE 4ECTi 3219
SE 4ECTi 3164
City/Hwy
Sedan/Coupe 4ECTi 20/29
Wagon 4ECTi 20/28
Ratko is offline
post #2 of 23 Old 03-07-2005, 06:30 PM
3rd 5-speed Camry...
87Camry5Speed's Avatar
Quoted: 4 Post(s)
Thumbs up
Ratko man idk where you found all this but damn... and thank you!
I always wondered why the steep drop in RPM's on the 1-2 shift on my 5-speed... now I know why... damn. Seriously it knocks you back from redline to 4k.
But I digress- thank you thank you thank you
Steve
Current Toyota fleet:
2004 Highlander Limited
2009 Scion tC 5-speed
Past:
'87, '95, and '08 Camry 5-speeds.
87Camry5Speed is offline
post #3 of 23 Old 03-07-2005, 10:28 PM
Always Under Construction
Quoted: 0 Post(s)
the specs for the V6 are the 1MZ-FE engines right? (cuz i've got 94 V6 1MZ-FE)
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline
post #4 of 23 Old 03-08-2005, 12:38 AM
TN Ass Man
DrtySthV6SE's Avatar
Quoted: 0 Post(s)
that says the 1mz takes premium gas 91 octane, i have always put regular in mine whats the deal???
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline
post #5 of 23 Old 03-08-2005, 10:09 AM
Quoted: 0 Post(s)
it "recommends" 91 octane or better for optimum performance but it really won't hurt the engine to use regular...i used regular for about a year and a half and just switch to premium recently and have gotten a little better gas mileage and better performance....but it's ur money
-Matt
post #6 of 23 Old 03-09-2005, 07:12 PM
Guess whos back
Quoted: 0 Post(s)
When you get knocked back down to 4k you are still in the powerband so no worry about why it knocks you down (its in the peak of the powerband too look at dynos for shift points)
2000 VW Golf: CAI Exhaust 18's Koni/Nuespeed
92 Camry- No motor Stock and Stock!
CamryWhat? is offline
post #7 of 23 Old 03-13-2005, 03:43 AM
Quoted: 0 Post(s)
I own a '96 Camry V6 LE sedan and have found this info very useful; thank you! I always put 87 octane in mine and have not had any problems with it. I fully filled it up with 91 octane a couple of times, but didn't notice much of a difference.
1996 Toyota Camry V6 LE
kman10587 is offline
post #8 of 23 Old 05-08-2005, 08:06 PM
The Greatest
Quoted: 0 Post(s)
Ratko, Where are you finding this info?
Because I have a free period at school now so I could try and put another one together for gen 4's or 5's.
CamNub is offline
post #9 of 23 Old 11-09-2005, 04:35 AM
Midship Captain
ModifierMR's Avatar
Quoted: 0 Post(s)
Wish he had gen5 up there
ModifierMR is offline
post #10 of 23 Old 11-13-2005, 02:33 PM
Quoted: 24 Post(s)
Gen 4 would be great...where did you find this?
hmmmmmmmm.
4.5 Gen XLE V6. Minor light mods.
AmanO is offline
post #11 of 23 Old 11-14-2005, 07:47 AM
The 6"4 Viking
Zandro's Avatar
Quoted: 0 Post(s)
Only 125hp? the eurpoean ones has 136hp
Zandro is offline
post #12 of 23 Old 03-24-2006, 04:28 PM
MadDawg's Avatar
Quoted: 0 Post(s)
4ECT 21/28
HUH... i got better gas mileage with my short ram intake... i just switched back to my stock now and i get like 27/34 mpg... weird... LEAD FOOTS :P
MadDawg is offline
post #13 of 23 Old 08-04-2007, 08:17 PM
Got HP? Give Me Some Plz!
REV.HAPPY's Avatar
Quoted: 0 Post(s)
Thanx Ratko for the sweet specs !
REV.HAPPY is offline
post #14 of 23 Old 09-15-2007, 11:05 AM
Quoted: 0 Post(s)
How do you set up the keyless remote for this car?
flamerid is offline
post #15 of 23 Old 09-15-2007, 12:17 PM
TN Pussy Man
Eye8Pussies's Avatar
Quoted: 0 Post(s)
iTrader Score: 13 reviews
you're not going to get any responses in this thread- best to stick to your thread in the main forum
HaHa
Eye8Pussies is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
