2000 camry passenger headlight out - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 4 Old 02-15-2017, 09:54 AM Thread Starter
Quoted: 62 Post(s)
(Thread Starter)
2000 Camry passenger side headlight, low beam, went out. Put in new. Still out. No 12v at connector.
From what I gather from the schematics I scrounged on the internet, there is a 20 A fuse for each light. In any case, both fuses look good (hard to remove) but when I pulled the one for the driver side (marked LH) it stayed on.
I also went by what is printed on the fuse box cover, which, one would hope, is accurate.
Signed, Puzzled.
joea is offline
post #2 of 4 Old 02-17-2017, 08:46 AM Thread Starter
Quoted: 62 Post(s)
(Thread Starter)
sorted. helps to actually work on the correct lamp. high/low, big deal. 9005/9006, bah, humbug.
joea is offline
post #3 of 4 Old 02-17-2017, 01:10 PM
Kingdom934's Avatar
Quoted: 1127 Post(s)
Wrong bulb?
'85 Camry DLX 162K
'87 Cressida 78K
'04 Camry XLE V6 108K
'98 Camry LE AE V6 216K
'06 IS250 + sport pkg 131K
'04 Camry SE I4 5SPD 167K
Kingdom934 is online now
post #4 of 4 Old 02-17-2017, 01:39 PM Thread Starter
Quoted: 62 Post(s)
(Thread Starter)
Originally Posted by Kingdom934 View Post
Wrong bulb?
Wrong bulb?
No. Dim bulb. Me. My low beam was out, but I was looking at the high beam. My excuse is I had just changed plugs, in below freezing weather and decided I would tackle the light right then.
I just pulled the wrong socket out.
The plugs were a very frustrating experience as the "grommet" that holds the plug in the socket refused to release the plug after tightening. When I did get the socket out, the grommet stayed behind. After playing that game for a while, I wanted to try the vacuum hose trick, but did not have any. I resorted to an old plug wire set, cutting off the hard plastic part that goes down the tube and trimming off the rubber seals. Holds the plug perfectly and is easy to slip down the tube and get the plug finger tight. You'd have to work real hard to cross thread it too.
The warm glow of success must have softened my brain.
joea is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
