Knock Sensor wire on 96 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 10-30-2006, 04:28 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation Knock Sensor wire on 96 Camry
Had an engine code come up on my 96 camry that pointed to the knock sensor. Upon inspection, the original shielded wire has been spliced and a short pitail of normal wire was run to cover the needed distance to the knock sensor. I'm guessing that this is causing the code as I was told that splicing the wire this way would disrupt the sensor signal, and that the wire had to be a predetermined length to work correctly. Sooo: 1) Is this correct? 2) Where can I find just the knock sensor wire without having to buy the whole wiring harness?
I understand that the knock sensor may be the culprit, but the spliced wire is surely suspect, and I thought I'd start at the point of least $$$$.
Any help is appreciated. Thanks.
Dusty
Dusty Drake is offline
post #2 of 6 Old 10-30-2006, 05:08 PM
Banned by a newb
Quoted: 0 Post(s)
Cool
If the wire is otherwise in good shape. I'd blame the sensor. It's shielded just to keep it from picking up EMI from the ignition system. But in our case, the ignitions are already shielded a good bit no their own so...
You check them both at the same time anyway, so check them both. I'd make sure that sensor isn't shot & grounding out tho.
Toysrme is offline
post #3 of 6 Old 10-30-2006, 05:27 PM
Quoted: 2 Post(s)
Is this an I4 or V6? What specific trouble code was read? There is more then one code for the knock sensor circuit. Do not think a specific length of harness wire is required. The knock sensor generates a signal when the engine is knocking. Could be a defective sensor(s), short or open wire to the sensor.
toyomoho is offline
post #4 of 6 Old 10-30-2006, 06:44 PM
TN Pussy Man
Eye8Pussies's Avatar
Quoted: 0 Post(s)
iTrader Score: 13 reviews
well, it's pretty easy to check if your knock sensor is dead or not- just use a multimeter and test the continuity of the sensor. if you get continuity, the sensor is blown. otherwise, it's still okay.
and no, the length of the wire doesn't matter.
and as well, no, the sensor doesn't only send a signal when it hears knocking- it actually sends a continuous variable signal to the ecu. that's why you can't just take the knock sensors out to trick the ecu.
if the sensor itself is still okay, check your ground on the block to the knock sensor- make sure it's clean, and resplice the wire yourself. If any part of the wiring is touching the shielding, it's being grounded before it even reaches the sensor.
HaHa
Eye8Pussies is offline
post #5 of 6 Old 10-30-2006, 07:49 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks for the help. I'll recheck everything. I do have an I4 - meant to put that in the first post but it didn't get there. So, assuming I'm not grounding out anywhere, I can splice into the shielded wire with no ill effect? If so, why is the shielded stuff there to begin with?
post #6 of 6 Old 10-30-2006, 08:40 PM
TN Pussy Man
Quoted: 0 Post(s)
^ yup, as long as you don't let the wiring touch the shielding around the wire
and not sure....because on the v6 which has 2 knock sensors, one is shielded and the other one isn't....
HaHa
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
