NOOB - Jack and Stand points - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 31 Old 10-31-2006, 06:58 PM Thread Starter
Toyota Camry Vienta CSi
Quoted: 0 Post(s)
(Thread Starter)
Hey,
I know this is really basic but I dont have a repair manual or even an owners manual, so I have no idea where to position the jack and stands (And I dont wanna take any risks... thing in the jack box says 20 ppl in the last 4 years have died from incorrect position etc when lifting a car)! Where abouts is the spot (Car is a 1993 Camry Vienta - think its LE in U.S... V6 3VZ-FE)? Im changing my oil for the first time, doing it on the cheap, but from what I can see under my car (hard to see anything its very low to the ground) the only point for the jack is just passed the plastic cover under the radiator at the very front, there is a bar running from left to right... is this the spot? Have no idea where to put the stands.
Any help appreciated... pics would be great but not essential
Aussie_Camry is offline
post #2 of 31 Old 10-31-2006, 07:12 PM
touringcamry's Avatar
Quoted: 3 Post(s)
Look for the scissor jack point and then look beyond that metal lip something that looks like a frame rail. Put the jack stands under that. Use thise for the front only.
2007 Camry 2.4L 5M
touringcamry is offline
post #3 of 31 Old 10-31-2006, 07:31 PM
Dealer Tech..not Toyota
Axel Kain's Avatar
Quoted: 0 Post(s)
well if that center cross bar has about a index fenger size hole in it, i know which 1 you are talking about, you can use it, but take it slow, and if you see it start to flex up, stop.
then option B (the more common prob. safer) on either side of the car, about where the door jamb is, look on the bottom. you'l see where the floor, and side of the car metal meet (looks like its been pinched out toward ground) thats a good spot to jack it up.
also while in that same area, look more towards the center of the car, you'll see a frame looking bar (one about under where the front seats are), they are about 2 inches wide, great for jacking / putting jackstands at.
good luck, and its easier to get the oil filter from the top (make sure engine is COOL!!!!).
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline
post #4 of 31 Old 10-31-2006, 08:46 PM
Member
Quoted: 0 Post(s)
If you're just jacking it up to get the the drain plug or filter, get those ramps that you can drive your front wheels up.
97 Camry LE I4 - 06 GS300 rims (11/06), Tokico HP/H&R Springs(1/07), Pioneer 7400MP, Polk DB675, OSRAM Silverstars (3/07), K&N filter
triggerhappy007 is offline
post #5 of 31 Old 10-31-2006, 10:42 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ive already got the stands and the jack though, and I will more than likely start buying more stuff for my car and do things like rotate tyres, change pads etc. Its also to expensive to get the ramps
LOL that doesnt instill me with much confidence... from what Ive been reading on the internet though I think the crossmember (thats its name I think of it) is the way to go.. it holds the engine up so surely it can take the weight! Still cant find any good places for the stands, the descriptions are alittle iffy, cant really see any spots where to put them.
Yeah I cant even find the scissor jack point, I look just passed the wheel and theirs nothing. On my mums car, its obvious where it is, not on my camry though!
Thanks for the replies so far though
post #6 of 31 Old 11-01-2006, 12:27 AM
Quoted: 3 Post(s)
The scissor jack point is to the rear of the front wheels. It is indicated by two notches. The lip between those two notches is the scissor jack point.
On the rear to the front of the rear wheels is something similar.
On the rear, I prefer to put the stands on that bar with the rear jack point. But if your stands don't reach that, I think that the same "rail" on the rear should be ok. I've done it before and nothing bad happened. It's just not where I like to put it.
2007 Camry 2.4L 5M
post #7 of 31 Old 11-01-2006, 04:57 AM
Where are we going today?
skewe's Avatar
Quoted: 0 Post(s)
look up car manual, they have the precise location mentioned in print
skewe is offline
post #8 of 31 Old 11-02-2006, 02:09 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I dont have the cars manual though, previous owner 'lost it'. I might just go to a shop and check our a repair manual or something, without buying it
post #9 of 31 Old 11-02-2006, 07:18 AM
96 3MZ M/T
chronoti's Avatar
Quoted: 0 Post(s)
go in the general discussion for the camry's there a link there to download the manual
^ and leaving it that way!
chronoti is offline
post #10 of 31 Old 11-02-2006, 08:09 AM
patrolman's Avatar
Quoted: 0 Post(s)
just pass the front wheel fender underneathe the door on either side of the car, a small 4 inch long black metal lip pertrudes from the car about 3-4 inches, its pretty recognizable.
1994 Toyota Camry Le
2007 Toyota Camry Se
patrolman is offline
post #11 of 31 Old 11-02-2006, 04:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ah ok I think I found it, its the first couple of inches that can be used correct... cos the lip does continue but isnt reinforced or something? Now I just need a spot for the jack!
post #12 of 31 Old 11-02-2006, 06:15 PM
2GR FTW
darksparkz's Avatar
Quoted: 1 Post(s)
http://oregonstate.edu/~tongt/camry/
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline
post #13 of 31 Old 11-02-2006, 07:48 PM
patrolman's Avatar
Quoted: 0 Post(s)
just slide the jack that comes with the car under that spot ---_____----- it looks kind of like that how it drops down and is reinforced in the front.... the ^ jack goes there.
post #14 of 31 Old 11-02-2006, 09:49 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ok sorry for sounding retarded but...
That spot is for putting the cars jack their for changing a tyre. Im doing an oil change.... cant use the cars jack at all for that AND I need a spot at the front in a central location to lift the front end of the car up from. The jack point you are referring to Im still not 100% sure with as well, I will post pics of under my car soon... on my mums car it is OBVIOUS where the jack point is, I cant find it at all on mine, maybe something is sus (I havent had this car for all its life)
post #15 of 31 Old 11-03-2006, 07:16 AM
Grenaded piston
88 LE's Avatar
Quoted: 3 Post(s)
Do not use the factory jack points to place your jack stands or as a jacking point for anything other then the factory jack (the one included with the car). Doing so will bend the shit out of that lip and that lip is to small for jack stands.
Place the jack stands under the frame rails.
Front: I slide the jack underneath the front of the car (in the middle) and jack it up by the subframe. The subframe is a thick piece of metal, so no worries bending it or anything.
Rear: Theres a hump that comes down from the rear suspension arms. I place the jack underneath that hump.
"Skoolin' the unlearned!"
88 LE is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
