1992 how to adjust camry idle? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 3 Old 02-15-2008, 01:32 AM Thread Starter
949
Quoted: 0 Post(s)
(Thread Starter)
1992
camry
4 cylinder
auto
original owner
155k miles
the idle seems to have increased over the years. is there anyway to adjust it down?
whats happening is after its warmed up the idle never goes lower then 1100rpm.
when the car was new it was sitting about 600-700 rpm.
so does anyone know how to adjust this thing?
i couldnt find a screw or anything on the throttle body.
949 is offline
post #2 of 3 Old 02-16-2008, 12:21 AM
Kep
Senior TN Member
Kep's Avatar
Quoted: 2 Post(s)
3SFE engine does have an adjustment. 5SFE, I don't know. However, I doubt if it has become un-adjusted. I suspect that you have a combination of a deteriorating sensor and/or dirty environmental system (IAC valve?). Also, the AC system has an idle up control. Maybe that is faulty. I would recommend a thorough cleaning and sensor testing before trying to adjust the idle.
Kep
Kep is offline
post #3 of 3 Old 02-16-2008, 12:29 AM
Senior TN Member
dc_98_cam's Avatar
Quoted: 110 Post(s)
Possible that the IAC rotary vane solenoid has become stuck ... not moving freely after cold engine startup sequence....
Also possible that a sensor ... maybe the oxygen sensor ... is sending an incorrect fuel adjustment signal to the ECU.
Is there any chance of checking the CEL codes in the ECU memory?.... There is a procedure for this ... OBD-1.
former owner 98 Camry LE, 2.2L, automatic
54k miles, drop in K&N A/F, ... timing belt, water pump, NSS
dc_98_cam is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
