Camry Won't Start After It Rains - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 18 Old 03-28-2008, 11:41 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a 93' Camry and I have been having the same problem for a few months now, about every other rain causes my camry to not start and I have replaced the distributor, the coil, and had the cap and wires checked out and the mechanics cannot find where the problem is coming from and sure enough after it rained yesterday my car wouldn't start... has anyone experience anything like this?
Slycat1236 is offline
post #2 of 18 Old 03-28-2008, 11:47 AM
93 Camry LE V6
Barcs's Avatar
Quoted: 0 Post(s)
Question. Is your engine wet at all after the rain?
Barcs
Barcs is offline
post #3 of 18 Old 03-28-2008, 12:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Yea I mean nothing extraordinary but yes it is
post #4 of 18 Old 03-28-2008, 01:46 PM
Quoted: 86 Post(s)
If you have already replaced the entire distributor including the coil, I would go ahead and replace the cap, rotor and wires. The wires could be bad, even if they ohm out OK, and the cap and rotor are cheap enough to just replace. They are the usual suspects after the internal coil itself.
Mike
Mike Gerber is offline
post #5 of 18 Old 03-28-2008, 04:11 PM
OREGONian
ToRn's Avatar
Quoted: 31 Post(s)
Quit peeing on your engine...
ToRn is online now
post #6 of 18 Old 03-29-2008, 01:21 PM
Quoted: 0 Post(s)
Emergency "stuck at the grocery store" fix would be the classic WD-40. Open the hood and spray the stuff on the outside of your distributer and plug wires. This drives off moisture that is shorting out your electrical system.
2001 Tacoma, 2RZ–FE, 161k
1994 Camry, 5SFE, automatic trans., 269k (junked july2013)
anti-seize is offline
post #7 of 18 Old 03-29-2008, 06:11 PM
Quoted: 0 Post(s)
I have the same problem. it's 1998 camry 5SFE. In cold winter morning or rainy afternoon, I need keep pressing gas to start engine. I checked in 2 garages, one suggested replacing ignition coil, one suggested replacing idle air control valve. I replaced spark plug and wires, it is same as before. Now decided to replace ignition coil because I can see some wet oil around the No. 2 (front) ignition coil but the No.1 ignition coil is dried well around.
camry98cool is offline
post #8 of 18 Old 03-29-2008, 07:00 PM
Quoted: 0 Post(s)
What's the cap? oil filler cap?
post #9 of 18 Old 03-30-2008, 02:27 AM
the honda killa
rholzboog's Avatar
Quoted: 0 Post(s)
i had the prob becuse my splash gard fell off it was the starter get some one to turn the key and pound on the starter or it might be in your fuse box ckeck the relays hope this helpes good luck pm me if you have more?
catch me if you can
rholzboog is offline
post #10 of 18 Old 03-30-2008, 05:33 AM
Lost to follow up!
Quoted: 1 Post(s)
iTrader Score: 59 reviews
Same thing use to happen to my previous 96 5sfe!
It was the corroded battery cables. One was broken, replaced it, (couple of bucks at napa)...never happened again!
eyeball96 is offline
post #11 of 18 Old 03-30-2008, 07:14 AM
Quoted: 0 Post(s)
may you explain it a little more detail, what's splash gard and where it is?
post #12 of 18 Old 03-30-2008, 02:30 PM
Quoted: 86 Post(s)
Slycat1236,
Let's start over again. Maybe I misread or misinterpreted your original post. Are you saying the starter doesn't crank (turn over) the engine, or that the engine cranks but will not run? The parts you mentioned replacing made me think it cranks, but will not run; but I may be wrong.
Mike
post #13 of 18 Old 04-01-2008, 04:40 AM
the honda killa
rholzboog's Avatar
Quoted: 0 Post(s)
under the frount bumper trans made of black plastic
catch me if you can
post #14 of 18 Old 04-11-2008, 01:22 PM
Quoted: 0 Post(s)
Hi,
I'm new to the forum.. found it while searching the net for info about this same problem. 96 Camry with a '95 5fse motor.
I've had starting problems twice now in three days. Both times after rain overnight. So I associate this problem with the moisture.
The starter engaged and it started to fire up, then quit. I then tried cranking again and it will crank for a while, then start to fire a little bit (maybe one or two cylinders ignite) but not enough to turn over and run.
Wed it happened to me, so I took the wife's car. Then that evening I replaced the plugs and managed to get it to fire up. It was definitely flooded!
It ran perfectly and started every time yesterday.
Then this morning after a night of rain, the same thing happened. Seems like it's getting fuel, but no spark on at least one cylinder. When that spark doesn't come, the combustion chamber fills with gas and then it floods out.
It seems to me that it's moisture getting in somewhere and causing a bad connection which prevents the plug or plugs from firing and thus allowing the motor to flood. Once flooded, the plugs get wet and just won't fire.
So what to fix?
Last summer i replaced the distributor (cap and rotor), wires, and plugs. I'd hope that I don't have to do that again.
I'm planning to recheck the connections between the rotor and plug wires, and between the wires and spark plugs.
I'll also check the connection at my MAF, and as suggested above, make sure my battery cables aren't corroded.
Can anyone else help with a remedy?
Eikon is offline
post #15 of 18 Old 04-11-2008, 01:56 PM
Quoted: 86 Post(s)
If the cap, rotor and wires are relatively new and are still in good shape (I say that since I have seen some cheap aftermarket ignition system components last 1 year or less), then the next logical problem would be a hairline crack in the coil inside the distributor. The moisture in wet/damp weather causes the cracked coil to short itself to any metal ground inside the distributor. Remove and inspect the coil carefully for cracks or just replace it. They are about $40 for an aftermarket coil.
Mike
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
« Back
