97 Camry Windshield Washer Sprayer - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 17 Old 11-12-2008, 07:39 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA 97 Camry Windshield Washer Sprayer
My first visit here. I am looking for a third party source for the windshield sprayers that are mounted on my hood. Toyota Service wants $22 for each one, and I need two. Does anyone know of a reliable and inexpensive source for these sprayers?
Thanx,
Froghair42
Froghair42 is offline
post #2 of 17 Old 11-12-2008, 07:52 PM
just a nobody
Quoted: 118 Post(s)
Excuse my curiosity, why would you need to replace both of them?
N.E.O.
new echo owner is offline
post #3 of 17 Old 11-12-2008, 10:39 PM
Quoted: 0 Post(s)
USA
I've got two I will sell you for $15.00, off a 1996 camry. Not sure if its the same sprayer on a gen 4 but I'm pretty sure.
proftomda is offline
post #4 of 17 Old 11-13-2008, 08:35 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA
Why do I need two sprayers? Because both of them spray over the roof of my Camry. Both have been clogged from calcium in the water, both have had straight pins stuck in the spray holes to clean them out, thus causing both of them to now spray over the top of my car.
post #5 of 17 Old 11-13-2008, 08:54 PM
just a nobody
Quoted: 118 Post(s)
You can use the same pin to aim them down lower, they are kind of like a ball with an orifice in the middle to spray the fluid.
N.E.O.
post #6 of 17 Old 11-14-2008, 08:07 AM
Darkside Cut Me!!!
Quoted: 3 Post(s)
I use a steel guitar string to clean and align the nozzles.
You should aim them a little higher when not moving with engine on.
With engine off, the spray is not as powerful and the coverage will be different when you drive.
When you drive, then the spray area should be correct.
2004 RX330 Sport
2004 Matrix XR
1998 CamCE I4 Super Commuter!
1997 CamLE I4
Gone:
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
Hajoca is offline
post #7 of 17 Old 11-14-2008, 02:00 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 878 Post(s)
So those nozzles are mounted like little ball joints??? Well I'll be!!... a couple of mine are mis-pointed a little, but I never bothered to check 'em out. Learn something every day around here! I bet a sewing needle would work well to adjust them, eh?
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 32k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 354k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #8 of 17 Old 11-14-2008, 02:56 PM
just a nobody
Quoted: 118 Post(s)
You got it!
N.E.O.
post #9 of 17 Old 02-19-2009, 07:35 PM
Quoted: 0 Post(s)
1996 camry spray nozzle
if no one's interested in those spray nozzles i could sure use one.
wilchilli
wilchilli is offline
post #10 of 17 Old 02-19-2009, 10:50 PM
cruisn76's Avatar
Quoted: 1 Post(s)
iTrader Score: 6 reviews
Personally I would change those nozzles if you have a GEN3 camry. I hate the 4 line spray. I love the ones that mist the entire windshield, like GEN6 Camrys. I think
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline
post #11 of 17 Old 02-20-2009, 11:51 AM
Darkside Cut Me!!!
Quoted: 3 Post(s)
The fans spray does not give as good of coverage to top of windscreen when you experience high winds or when you drive on highway.
2004 RX330 Sport
2004 Matrix XR
1997 CamLE I4
Gone:
2003 Cam I4 XLE
Hajoca is offline
post #12 of 17 Old 08-03-2009, 03:34 PM
Chris Crash's Avatar
Quoted: 30 Post(s)
iTrader Score: 13 reviews
Does anyone know how to remove these?
I can't find a way to pull them out.
Both of them broke on the underside and I need new ones now.
Chris Crash is offline
post #13 of 17 Old 08-03-2009, 03:48 PM
Quoted: 0 Post(s)
Open hood, peel back sound deadener blanket, locate fluid line going to nozzle in question, pull fluid line off back of nozzle, use needle nose or reg pliars and squeeze each side of nozzle as you push nozzle out of hole in hood, done.
post #14 of 17 Old 08-04-2009, 01:10 AM
Quoted: 30 Post(s)
Yeah, I called the dealership and they wanted $19 each.
So I decided I'll fix my broken ones!
...and I did!
I'm so happy I have sprayers again.
post #15 of 17 Old 03-12-2014, 04:44 PM
Quoted: 1 Post(s)
I know this is an old post, but I need to resurrect it. I need one (but will take both if necessary) one spray nozzle for my 96 Camry. The old one cannot be repaired, thus the need for a replacement. If anyone has one, please leave a message here or PM me.
thanks,
Mike
marragtop is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
