1999 camry coolant leak - where is it coming from? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 9 Old 05-03-2009, 05:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
My 1999 Toyota Camry overheated the other day due to low to zero coolant. I popped open the hood and found this leak. Where exactly is it coming from? How much would the repair be?
njpnoy05 is offline
post #2 of 9 Old 05-03-2009, 05:59 PM
Ninja wrench anywhere
hill8570's Avatar
Quoted: 3 Post(s)
Looks like she's weeping out of the water pump. Cost depends on the shop and whether or not you want OEM parts...$150 minimum.
If your timing belt is coming up for replacement, this would be a good time to do it -- same basic disassembly.
hill8570 is offline
post #3 of 9 Old 05-03-2009, 08:55 PM
Quoted: 0 Post(s)
i paid $410 to replace water pump at Toyota of North Hollywood CA just 2 weeks back.
mnsweeps is offline
post #4 of 9 Old 05-03-2009, 08:57 PM
Quoted: 0 Post(s)
also i replaced the green coolant with dealer recommended red coolant. You might want to do the same.
mnsweeps is offline
post #5 of 9 Old 05-04-2009, 05:24 PM
Senior TN Member
carsrus's Avatar
Quoted: 172 Post(s)
410 to replace the waterpump is outrageous. A new pump from NAPA is 60$. Since your gonna be replacing the pump you might as well do the belts and seals in there.
carsrus is offline
post #6 of 9 Old 05-04-2009, 06:43 PM
Quoted: 0 Post(s)
I just did this job
Same thing 99 Camry 5FSE - 98k miles.
Timing belt, timing belt tensioner spring replacement, camshaft oil seal, crankshaft oil seal, oil pump oil seal, oil pump O-ring gasket, water pump (gaskets come with the new pump) and head cover gasket.
total job time around 6 hours.
The water pump at the dealer is around $130. Stick with dealer parts they are much better than the Chinese one you'll get in the auto store for cheap. If you get the water pump at the dealer you already know how many miles it will last. If you get the one at the auto store it's pot luck.
I would think the flat rate for water pump would be around 3-4 hours. Sounds like around $450 to me.
jmborchers is offline
post #7 of 9 Old 05-04-2009, 09:06 PM
hill8570's Avatar
Quoted: 3 Post(s)
List on the OEM pump (which includes the housing -- most cheapies charge extra for that) is $110 for the 4-banger, $120 for the 6-banger. From www.toyotaoemparts.com, $83/$89 plus shipping, respectively. Probably about the same from www.1sttoyotaparts.com . Flat rate is right at three hours, but most non-dealer shops will cut you some slack, since it doesn't take anywhere near that amount of time in reality. I'd expect that a decent non-dealer shop could do it for $250, even using OEM parts.
hill8570 is offline
post #8 of 9 Old 05-05-2009, 05:39 AM
Senior TN Member
Quoted: 453 Post(s)
Leak looks like it's coming from WP gasket. Could be as simple as checking tightness of WP mounting bolts. Try that first. Green fluid is fine.
1995 Camry Wagon LE. 2.2 5S-FE, Auto, 233K
Stillrunning is offline
post #9 of 9 Old 05-07-2009, 12:15 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
turned out to be a damaged water pump. the mechanic replaced the pump, gasket, and the surrounding belts. added up to 493. thanks for the replies ya'll.
njpnoy05 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
