1997 Camry front sway bar links and bushings need replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 20 Old 05-04-2009, 11:02 PM Thread Starter
MIK1989's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Hi to everyone. The shop diagnosed that my front sway bar links and bushings need to be replaced. They ask $500 for it, I think it's too much for this kind of job, all the parts cost around $100. So I'm thinking doing it myself.
What instruments I must have? Any lubricants?
I have never done it before, can someone point me DIY for this?
Thank you.
Toyota Camry XLE 1997, V6 (1MZ-FE)
MIK1989 is offline
post #2 of 20 Old 05-05-2009, 01:09 AM
RU2CHKN?
RU2CHKN's Avatar
Quoted: 0 Post(s)
You'll need a 5 mm hex wrench or possibly some vicegrips and get some lithium grease to lubricate the bushings
RU2CHKN is offline
post #3 of 20 Old 05-05-2009, 09:04 AM
Darkside Cut Me!!!
Quoted: 3 Post(s)
Rust penetrant like PB Blaster, or Release-All, Kriol will make it alot easier. Torch if you are very rusty.
Above mentioned 5mm hex, You can go to CTire or Sears and get the 5mm hex (like allen key) set into a socket which will give you alot more torque and control.
2004 RX330 Sport
2004 Matrix XR
1998 CamCE I4 Super Commuter!
1997 CamLE I4
Gone:
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
Hajoca is offline
post #4 of 20 Old 05-05-2009, 09:17 AM
Quoted: 98 Post(s)
iTrader Score: 16 reviews
1st off, get a can of PB Blaster, a set of hex sockets, and a set of ratcheting wrenches (pics below).
You don;t need grease.
For the sway bar bushings, you really should have the ratcheting wrenches. They are a BITCH to do due to the size. Not really hard, just takes some time is all.
For the sway bar links, chances are they will be rusted on. But it;s worth a try to correctly remove them. Start drenching them with PB Blaster a couple hours before starting work. Spay the 4 nuts a several times over those couple hours. You have to put the 5mm hex into the middle, and then turn the nut with the wrench (you'll likely need to hit it with a hammer). I'll give it a 20% chance it will come off if they are original. If they don;t you'll have to carefullky grind them off with either a grinder or a dremel.
My Camry: http://www.cardomain.com/ride/228043...y-xle-sedan-4d
'96 Camry: 2MZ
'95 AE101: JDM Tails/Grill/BiXenon Headlights. JDM Lighted Ignition Keyring and Cabin Air Filter
ASG14 is offline
post #5 of 20 Old 05-05-2009, 10:08 AM
RU2CHKN?
RU2CHKN's Avatar
Quoted: 0 Post(s)
^Mmm gear wrenches lol
RU2CHKN is offline
post #6 of 20 Old 05-05-2009, 02:44 PM Thread Starter
MIK1989's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I got the hex sockets and ratcheting wrenches. Also I went to get some grease, cuz people say you have to put it on bushings, I'm not too sure. It won't hurt the bushings if I put it on, right?
So, I went to buy links and bushings to the parts store, and for links they gave me these:
But on ebay I found that links should be longer for 97-01 models, these seem to be for 92-96 models.
I went to the store again, and they said that these are the right links for my Camry, for 98 they have different ones, but not for 97. I'm confused.
Did they gave me the right ones or no?
MIK1989 is offline
post #7 of 20 Old 05-05-2009, 02:58 PM
Quoted: 98 Post(s)
Your parts stor is full of moron's.
92-96 (Gen 3) and 97-01 (Gen 4) are 2 different types. I'll be honest, I forgot what the gen 4 ones look like. but the '97 one's are the same as the '98-'01 (According to Toyota parts catalogue)
'96 Camry: 2MZ
ASG14 is offline
post #8 of 20 Old 05-05-2009, 03:04 PM
gcozmo's Avatar
Quoted: 0 Post(s)
I changed the ones on my '97 and they are at least 4 or 5 times longer than those.
Greg
'97 Toyota Camry
'07 Ford F-150
gcozmo is offline
post #9 of 20 Old 05-05-2009, 03:11 PM
Quoted: 0 Post(s)
4th Generation
I just recently replaced my struts and strut mounts on my '97 Camry and in doing so I had to remove my links. Trust me those are not the right links. I would estimate the length at about 8 inches.
pilce is offline
post #10 of 20 Old 05-05-2009, 03:32 PM Thread Starter
MIK1989's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Ok, I will go tell them I need different ones.
How about bushings. Are these the right ones? (Same bushing from different angles)
I found this picture on ebay that represent front links. Are these right ones?
Also, when you put new ones in do you need torque wrench, to adjust tightness?
MIK1989 is offline
post #11 of 20 Old 05-05-2009, 09:51 PM
Darkside Cut Me!!!
Quoted: 3 Post(s)
Links look fine for Gen4.
Bushings... is ther e a number like 18 or 17 moulded on the bushing (that is hole diameter) or measure inside diameter yourself.
2004 RX330 Sport
2004 Matrix XR
1997 CamLE I4
Gone:
2003 Cam I4 XLE
Hajoca is offline
post #12 of 20 Old 05-06-2009, 01:24 AM Thread Starter
MIK1989's Avatar
Quoted: 0 Post(s)
(Thread Starter)
The number on the bushing says 17
MIK1989 is offline
post #13 of 20 Old 05-06-2009, 10:25 AM
Quoted: 0 Post(s)
return those. those are gen3 sway bar endlinks. dont get the ones off ebay, if there is too much stress on them, they will snap at the welds, ive gone through 2 of them. just get the MOOG part ones. they are thicker and have zirc fittings so that they can be regreased. My car is really low, so when i raise up one side of the front end, it puts a lot of stress on the sway bar endlinks, the moog or OEM are the only ones i trust.
goodluck
Charley
charley240sx is offline
post #14 of 20 Old 05-06-2009, 02:10 PM Thread Starter
MIK1989's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I exchanged those for Moog ones. So when I'm going to install them I have to put grease inside? How do I do that?
MIK1989 is offline
post #15 of 20 Old 05-06-2009, 03:05 PM
PortugalFocus's Avatar
Quoted: 1 Post(s)
The same place you bought the end links should sell a grease gun. Get one with a few tubes of grease. It shouldn't cost more than $20-25.
PortugalFocus is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
