'94 Camry Eng Stopped While Driving - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 12 Old 08-31-2009, 08:57 AM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
USA '94 Camry Eng Stopped While Driving
I was out driving @ 55mph. Divided highway ended with red traffic light. I turned off cruise control and engine stopped running. Pushed car to parking lot off road. Unable to restart. Plenty of gasoline. Battery strong.
What do I look for first to get this running again?
Which fuse might be bad?
How do I check fuel flow?
How do I check dist? coil?
Where can I see exploded engine views?
dickb
dickb is offline
post #2 of 12 Old 08-31-2009, 09:23 AM
PortugalFocus's Avatar
Quoted: 1 Post(s)
does it turn over freely with the starter? if so check for spark then check for fuel. Start there.
PortugalFocus is offline
post #3 of 12 Old 08-31-2009, 09:26 AM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
Turns over freely. This car is fairly new to me, how do I get to the plugs?
dickb is offline
post #4 of 12 Old 08-31-2009, 09:35 AM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
I don't have the car in front of me but, I think the engine looks similar to this one < http://enginespro.com/index.php?main...s37njpc08lvqb0 >
dickb is offline
post #5 of 12 Old 08-31-2009, 02:41 PM
Quoted: 0 Post(s)
My car died on me while driving home from work one day. Had actually just gotten back from a 2 hr drive at 70mph just the day prior.
It turned freely but wouldn't ignite. Turned out the timing belt was gone.
Wouldn't have known if I didnt take it to the shop, so i towed it there and $700 later, it was back, running better than ever.
cinkmoot is offline
post #6 of 12 Old 08-31-2009, 03:12 PM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
I hope it is not the belt. That would prob total the car. I dont't think it is worth dumping more into this beater. I disconnected the fuel line and it pumped fuel. I couldn't even see a spark plug wire to disconnect to look for a spark. Wouldn't a broken timing belt ruin the engine? (interference/non-interference?)
dickb is offline
post #7 of 12 Old 08-31-2009, 03:21 PM
Slowly learning....
Quoted: 0 Post(s)
Timing belt won't hurt the engine. It's non-interference.
However that will run you at least 500 dollars if you use genuine parts.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline
post #8 of 12 Old 08-31-2009, 05:20 PM
whip_cracker's Avatar
Quoted: 0 Post(s)
Um, don't spose the cruise control module's broken and closed the butterfly clip?
whip_cracker is offline
post #9 of 12 Old 08-31-2009, 07:50 PM
Quoted: 0 Post(s)
I've had the same wonderful experience, except I was going 70 mph and the engine just died and would not restart. It was the timing belt. My second guess would be the distibutor coil. YMMV
finfinder is offline
post #10 of 12 Old 09-01-2009, 07:56 PM
Quoted: 1 Post(s)
Another thing I'd check is the AM2 fuse in the engine fuse box (front left side on my 93 XLE). There is a noise supression capacitor in the distributor that can short out and blow this fuse. It will look like an ignition problem when you troubleshoot it. I understand you can replace the capacitor (~$10), but before I figured this out, I had already put a junkyard distributor on (~$100). That did the trick.
mgiltm is offline
post #11 of 12 Old 09-01-2009, 08:01 PM
Senior TN Member
carsrus's Avatar
Quoted: 172 Post(s)
Simple thing to do is unscrew the timing cover a bit and have someone look to see if the cam is rotating when you crank the engine.
If its not then belt is either broke or chewed up.
carsrus is offline
post #12 of 12 Old 09-04-2009, 09:51 PM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
It is the Timing Belt. Looks like $700 including changing the water pump and idler arm.
dickb is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
« Back
