How do you adjust the parking brake on a Camry w/ rear discs - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 7 Old 11-02-2009, 05:29 PM Thread Starter
Toyota | moving forward
islandboy57's Avatar
Quoted: 29 Post(s)
(Thread Starter)
3rd Generation How do you adjust the parking brake on a Camry w/ rear discs
The parking brake on my mom's gen 3.5 is only a few clicks from the floor when I engage it. It holds the car but eventually it's going to go all the way to the floor. How do I adjust it? It's got the drum-in-disc parking brake setup since it's a V6 with discs in the back.
I did a quick search but there's mostly threads on I4s with drums in the back.
Thanks
'16 Camry LE - 3K miles
'15 Camry SE - 11K miles
'13 Corolla LE - 18K miles
islandboy57 is offline
post #2 of 7 Old 11-02-2009, 05:39 PM
Ninja wrench anywhere
hill8570's Avatar
Quoted: 3 Post(s)
OK, I'm sort of guessing (sorry), but most Toys will self-adjust if you work the parking brake multiple times.
hill8570 is offline
post #3 of 7 Old 11-02-2009, 07:16 PM
mixed bag 'o vehicles
ghettosled's Avatar
Quoted: 6 Post(s)
since i dont have discs on my camry i can only reference other vehicles.
on jeeps, if you crawl under the car and look at the backside of the drum area on the disc, there is a small rubber dust cover (about .5" x 1"). remove that and you will have access to the star adjuster. it should only spin in the direction to tighten. tighten a couple of clicks on each side. try it and repeat if necessary. dont overtighten and cause drag. if this happens, there is a metal arm that makes the clicking noise when tightening. hold that down and spin the star wheel the opposite way.
ghettosled is offline
post #4 of 7 Old 11-02-2009, 07:42 PM
Canyon Killer
Quoted: 0 Post(s)
There are two spots. You need to make sure to adjust both, otherwise your handbrake "pressure equalizer" will start to hit something under the car and make a noise when you hit it. The first adjustment is at the handbrake, the second is the star wheels inside the rear brake drums. Make sure to adjust the same amount of clicks on both sides when doing this adjustment. If the handbrake shoes are starting to wear (if you yank the ebrake while moving), then you will need to replace them if they are low (pain in the butt).
Let me know if you have any other questions. I have adjusted mine a bunch, so I can probably answer any other questions.
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
ekopel is offline
post #5 of 7 Old 11-02-2009, 08:41 PM
Senior TN Member
Quoted: 3 Post(s)
adjustment should just be like the drums... that's essentially what the parking brake for the rear discs are. remove the plug from the rotor hat, and adjust the star adjuster till its at the proper tightness. if the gen 3 rear discs are anything like the gen 5's, you won't have to worry about pushing back the self adjuster bar to undo a few clicks if its too tight like on the drums. the "clicking" for the star adjuster is simply a spring, no metal bar. see the picture below.
here's the gen 5... should be pretty similiar:
2005 Camry "LE"
LE05 is offline
post #6 of 7 Old 11-03-2009, 08:39 AM
Darkside Cut Me!!!
Quoted: 3 Post(s)
I always adjust like this:
Pull the handle up and down a few times and then leave it at one click
then adjust the drum shoes till they just catch.
Pull handle up and down a few more times, with handle off, there should be no drag at all. 2 clicks should engage the shoes and you cannot turn by hand at the drum/disc.
2004 RX330 Sport
2004 Matrix XR
1998 CamCE I4 Super Commuter!
1997 CamLE I4
Gone:
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
Hajoca is offline
post #7 of 7 Old 01-02-2014, 04:26 AM
Quoted: 0 Post(s)
Great posting/pictures.
I have trouble with the park-brake for my 1996 Camry Wagon (also called Scepter I found out).
I have exactly this brake-model. Disc-brake rotor combined with internal brake-shoes for parking brake.
The problem is: I can reverse with no problem, but driving forward makes the wheel stuck. Why??? Help me.
I took it apart yesterday (the day with 5 cm snowing of course...Norway...), but could not figure out why its "stucking" som I now drive without the brake-shoes (flat parking only :-)
I thought I made enough notes, but forgot something.
Se the parts-drawing in the link. Which side is of the lever is the right "shoe-hold-down-pin" going?
A or B?
More pictures:
http://imgur.com/a/PLFQd#0
And the washer with the little arm for the "shoe-hold-down-pin/spring", where is the little arm going? Into the hole? I found picture in another thread here, but I mistake the posision is wrong. Mine was in the holes.
Thanks.
cmry1996 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
