Battery Group Size? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 13 Old 11-08-2009, 09:32 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Battery Group Size?
Can anyone tell me the battery group size for 1997 camry v6. i have a 35 in now but why do the parts stores say a 24 will fit also. I would rather get a 24 it has higher CCA it's cheaper but is a bigger in dimensions. Will it fit in the battery area
300kmi97camry is offline
post #2 of 13 Old 11-08-2009, 10:17 AM
Woo Hoo!!
sbushnak's Avatar
Quoted: 0 Post(s)
You can use any of these 2 sizes. My old battery was a 35 and then I replaced it with a 24 last month. It should fit with no problem.
1997 Toyota Camry LE I4
@ 193,000 miles
sbushnak is offline
post #3 of 13 Old 11-08-2009, 11:45 AM
Senior TN Member
Quoted: 0 Post(s)
i would stick with whats on the car already.
(example)if it has 34 batt then buy 34 batt.
abew330 is offline
post #4 of 13 Old 11-08-2009, 12:35 PM
Quoted: 0 Post(s)
Will the 24 fit a 5S-FE Camry?
Kenny_McCormic is offline
post #5 of 13 Old 11-08-2009, 12:50 PM
イリジウム
Quoted: 298 Post(s)
Did someone slipped a smaller, cheaper battery in there?
You usually want the largest battery that fits. The 24 also gives you higher reserve capacity. I'd stay away from the smaller 35 unless you have to use it (clearance issues).
Interstate (a Johnson Controls brand, Walmart, Autozone Duralast Gold, etc), also has a higher capacity version of 24 that's 0.75" longer. It may not fit into the standard Group 24 battery heat shield.
Check the side of the POS and NEG posts. You may need the 24F instead of the 24. The same battery, but POS are on different sides.
You can find those info on interstatebatteries.com. However the link doesn't seem to work, so you'll have to type it in yourself. Or try it later:
http://www.interstatebatteries.com/c...egatron2_f.asp
JohnGD is offline
The Following User Says Thank You to JohnGD For This Useful Post:
CrystalMethod (04-02-2013)
post #6 of 13 Old 04-02-2013, 06:20 PM
Quoted: 1 Post(s)
4th Generation It's the Winter Weather Package
I have a 2000 Camry that came with a 24F battery from the factory. Cars that were sold in Northern states or Canada were typically equipped with a "Winter Weather Package" that included "heavy duty" upgrades to the starter, heater and so on. In the case of the battery, cars with this package came with a size 24 battery installed in place of the standard size 35. Either will fit as a replacement; the 35 will simply have more empty space around it.
JonBoy470 is offline
post #7 of 13 Old 04-02-2013, 06:46 PM
Senior TN Member
Quoted: 2 Post(s)
Upgrade to the battery I knew was standard for the car to even be sold in Canada. There is no "Winter Weather Package" up here, unless it is an option added by the individual dealer.
Cars that are qualified for sale in Canada have to meet certain requirements (due to winter conditions here, and applies to ALL cars sold in Canada, not just Toyota's). Of which any Camry has (any version), except for the battery (so, these were upgraded for the cars sold here). There is no "upgraded starter" for the Canadian market. Unless, you're talking about a remote starter (which is an option, and not a requirement). The only "upgrade" to the heating system would be a block heater (also an option, but also not a requirement).
As for the OP's post, I'd go with JohnGD's suggestion, and get the biggest battery that will fit, and has the positive and negative terminals on the correct sides of the battery.
CrystalMethod is offline
post #8 of 13 Old 04-03-2013, 12:08 AM
Dave's
Quoted: 26 Post(s)
Just thought I would mention a 24 has the posts reversed from a 24F (which can sometimes be hard to find I'm told). This could be the reason someone used a 35- which has posts matching the 24F. If you actually purchase a 24 you may find the cables won't reach. FWIW
Dave's is offline
post #9 of 13 Old 04-03-2013, 12:41 AM
Super Moderator
heartdisease's Avatar
Quoted: 2210 Post(s)
Holy thread revival. 3 and a half years and a new user comes in to answer a question on his first post?
Welcome to TN JonBoy470
heartdisease is online now
post #10 of 13 Old 04-03-2013, 06:15 AM
Senior TN Member
Quoted: 2 Post(s)
Occasional thread revival is sometimes a good thing.
post #11 of 13 Old 04-03-2013, 10:26 AM
Super Moderator
O sure not debating that just wondering how this came to his attention and enough for him to post in it after there had been no activity for over three years. I am glad it was of some use to you though.
post #12 of 13 Old 04-03-2013, 07:59 PM
Dave's
Quoted: 26 Post(s)
Didn't even notice. Probably because some of us just hit 'New Posts' and scan thru them. Of course, for a noob I guess they would all be new posts.
Dave's is offline
post #13 of 13 Old 04-08-2013, 07:31 AM
Quoted: 0 Post(s)
2000 Camry Battery
Bought my 2000 LE 2.2 with a new Interstate Group 35 in it - only drive it once a week for 25 miles - after 1 yr it wouldn't start after sitting for 3-4 days - alternator, connections, parasitic draw(30mA), etc. all checked out good - got it replaced under warranty - 1 yr later same thing - found out they were sulfating because of non-use - switched to a Group 24fn (750 CCA instead of 550 for group 35, the n is for cold climates) and I will charge it fully once a month.
Got the Everstart Maxx from Walmart ($95 - made by Johnson Controls who also make Interstate, etc) and rated as one of the best batteries you can buy.
HermitLoon is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
