Check Engine Light P0325 (Knock Sensor) - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 11-24-2009, 06:34 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
I have a 99 Camry (4 cylinder) with 118K miles. The wife was driving today and the CEL came on. Took it to Autozone & they pulled a code of P0325. It showed a probable cause of a faulty knock sensor. Has anyone replaced one of these and any good advice? It took me a while to locate it & had to jack up the car high and crawl underneath it to reach it. Took a couple of photos for reference. Do these go out now & then? The Toyota dealer wanted $202.46 (Part No. 89615-32030). Just hoping to replace the right part & save a little money. It looks like if I unbolt the long bar to the left I will have a lot more room to work with. Here are the pics, thanks for any comments:
http://s891.photobucket.com/albums/a...sor99Camry.jpg
http://s891.photobucket.com/albums/a...or299Camry.jpg
http://s891.photobucket.com/albums/a...or399Camry.jpg
dave1811 is offline
post #2 of 6 Old 11-24-2009, 09:24 PM
Senior TN Member
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Quoted: 4 Post(s)
How is the car running? Does it seem sluggish or slow to accellerate? Have you done any wiring modifications? Try the simple fix first, disconnect, clean and reconnect. If the car is running fine then just reset the (cel) check engine light and keep an eye on engine performance.
When you get this code, the ECM will operate in fail-safe mode to protect the engine. You will notice that your vehicle will not accelerate like it used to. The ECU won't throw a knock sensor code for actual knocking. They simply retard ignition timing more and more until the knock goes away, then it starts adding timing back until it's at base timing, or knocking comes back.
It worked fine until I fixed it!
csaxon is offline
post #3 of 6 Old 11-24-2009, 09:39 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
No wiring modifications, anything like that. Just had the car a couple of weeks. Had the timing belt & water pump replaced around a week ago but it has been running fine. I think it was coincidence that it was just coincidence that the light came on. I will try taking it out cleaning, it, etc. It appears that there is just one wire running to it, would that be right?
Thanks for the suggestions!
Dave
dave1811 is offline
post #4 of 6 Old 11-24-2009, 09:49 PM
Senior TN Member
carsrus's Avatar
Quoted: 172 Post(s)
Dave
The knock sensor code and the timing belt job are probably related. The sensor is right by that area. Its likely that the wiring might have gotten damaged leading to it. If you go the timing done at a shop I would take it back and complain.
If im right the knock sensor is a little lower then the timing cover and to the right of the crank shaft pulley or so. Really likely a wire got pinched etc.
carsrus is offline
post #5 of 6 Old 11-25-2009, 11:50 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Does anyone know if the knock sensor wiring goes directly from the sensor to the ECU located behind the glove box? I am assuming it runs through the firewall. And from what I could see, it is not close to the timing cover/water pump area. I guess a wire could have got pinched, I don't know. It has thrown the code when the car has accelerated onto the freeway. I cleared the code tonight by taking off the negative battery cable but it came on around 5 miles later when accelerating onto the highway.
Any more thoughts on this?
Thanks,
Dave
dave1811 is offline
post #6 of 6 Old 11-27-2009, 11:27 AM
Camry: 94-I4 and 94-V6
Quoted: 8 Post(s)
As someone had said, disconnect the grey plug, clean a little, then re-seat.
It's not cheap to replace.
But its presence is very important to protect the head gasket and the piston.
Engine would stay in open-loop (bad for gas) mode as long as the error code for this is on.
PS: yes, wires go to ECM, together with a bunch of other wires of course.
sintox is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
