120 Amp Main Fuse - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 3 Old 11-29-2009, 01:53 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
120 Amp Main Fuse
Hi - Has anyone ever removed/replaced the 120 amp main fuse under the hood. The fuse has a bolt/pin holding in place and I think the fuse boxe needs to be taken apart to remove the fuse?
Thx,
Bob
ponti_33609 is offline
post #2 of 3 Old 12-03-2009, 12:04 PM
mr.popo
Quoted: 0 Post(s)
it is bolted into the fuse box which will have to be removed and the bottom cover taken off to get to the bolts that connect it
'99 Solara SLEV6
geminimouse is offline
post #3 of 3 Old 08-28-2010, 09:33 PM
Quoted: 0 Post(s)
120amp Alternator fuse
The 120 amp fuse has long prongs with circular holes in them, two small hex bolts go side to side through the casing into the prongs. The only way to see the bolts is to lift up the entire plastic grid that all the other sockets go into. The grid snaps on/off the main housing which lies underneath. There are 4 plastic tabs that need to be pushed inward with a flathead screwdriver in order for the grid to be lifted. I do not own a Solera, but it is quite possible another fuse is housed next to one of the bolts, with it's own separate small plastic housing. It likely can be slid down and removed, so you can access the bolt. On my vehicle the bolts that hold the 120 amp fuse, are different sizes. The one on the right is slightly larger and can be removed with an 8mm hex socket with a 3" extension on the handle. The left hex bolt slightly smaller and is attached to some small wires (to the alternator) and a smaller 7mm socket is used.
myphx is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
