oil engine for camry 1998 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 85 Old 10-22-2010, 01:13 AM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
Hi,
What kind of oil engine should i use with my Camry 1998? The mileage of this car is around 90000.
At this age, should i just stick with 5W-30 oil engine? or go to 10W-30 or something else...?
Your comment and advice will be very much appreciated.
Regards,
Kimsan
sanlen is offline
post #2 of 85 Old 10-22-2010, 01:27 AM
Freakin Scooters
LynchburgCSI's Avatar
Quoted: 0 Post(s)
iTrader Score: 16 reviews
Both viscosities are withen spec. Check your owners manual for which to use depending on temperatures where you live. Should you switch your oil because of the age of the car? No. You can go to a high mileage oil if you like.
Honda Scoots Galore
LynchburgCSI is offline
post #3 of 85 Old 10-22-2010, 01:38 AM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
Hi,
Thanks for you advice.
The everage temperatures during dry season is between 30 C and 35 C. During raining seasons is normally less than 30 C
Please advice.
Regards,
Kimsan
sanlen is offline
post #4 of 85 Old 10-22-2010, 02:38 AM
Freakin Scooters
Quoted: 0 Post(s)
Sticking with 5w-30 should be okay unless temperatures go lower than 0C. (For those of us in the United States, 30-35 Celsius is 86-95 Fahrenheit.)
edit: see post below!
Honda Scoots Galore
post #5 of 85 Old 10-22-2010, 05:43 PM
Quoted: 86 Post(s)
The recommended oil should be printed on the oil cap, assuming it is the origianl cap. I would stick with whatever that says. My guess is it says 5W-30.
Mike
Mike Gerber is offline
post #6 of 85 Old 10-22-2010, 06:19 PM
I wrench, therefore I am!
Quoted: 0 Post(s)
What does your owners manual say for your temperatures? Available online at toyota.com if you don't have paper copy.
TedL is offline
post #7 of 85 Old 10-22-2010, 06:21 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 10 Post(s)
yeah, don't change viscosity to anything not recommended in Owner's Guide. most Toyota (covered by this section of forums) are recommended to run on 5w-30 in colder climates (or more variable) while 10w-30 can be used instead in warmer climates (always above -18C/0F).
at least this is how I read the guide (pic borrowed from another thread, based on gen4 camry engines 5s-fe and 1mz-fe):
as mentioned above, you can switch type of oil to High Mileage if you feel it would help or if you have some seeping seals (though it's rather recommended to fix them mechanically and not chemically).
you can also switch engine oil type from mineral (dino/classic) to synthetic of same viscosity if you like, it will benefit you with longer oil change intervals (synthetics wear down slower than dino oils).
'02 Solara SLE V6 1MZ-FE/A541E@ 154k
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
fenixus is offline
post #8 of 85 Old 10-22-2010, 07:51 PM
Freakin Scooters
Quoted: 0 Post(s)
^ Thanks for that. I thought 10w-30 was the sub-32 degrees oil. Whoops....
Honda Scoots Galore
post #9 of 85 Old 10-22-2010, 07:53 PM
Turbo Snail
Perkins's Avatar
Quoted: 6 Post(s)
iTrader Score: 8 reviews
10w30 is recommended for higher mileage motors though. Helps with oil pressure
Perkins is offline
post #10 of 85 Old 10-22-2010, 08:10 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 10 Post(s)
hmm... didn't realize 10w-30 is better for HM engines.
maybe I will start running my noisy 5s-fe on 10w-30 since Spring (I have 5w-30 M1 FS for Winter) and see what happens.
fenixus is offline
post #11 of 85 Old 10-22-2010, 08:17 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 10 Post(s)
hey, no probs
that pic is in owner's guide anyways hehe
I edited post above as I made a typo regarding 10w-30 recommended outside temp range. it should be above -18C/0F and not above 0C/32F.
fenixus is offline
post #12 of 85 Old 10-22-2010, 08:21 PM
Turbo Snail
Perkins's Avatar
Quoted: 6 Post(s)
Well the 10w30 is a higher viscosity (thicker) than the 5w30
the 5w30 is good for cold starts though because it lubricates the motor faster
5W-30 or the 10W-30 is strictly a matter of choice. With the small differences in kinematic viscosity you would be hard-pressed to detect these differences on initial engine start-up without specialized engine test equipment.
at operating temperature both of these oils work pretty much the same though. I wouldn't switch to 10w30 for the winter though because 5w30 is designed to pressurize better in cold conditions. 10w30 is too thick to build the right amount of pressure and takes longer to heat up than 5w30 ( poor circulation )
Perkins is offline
post #13 of 85 Old 10-22-2010, 08:26 PM
Freakin Scooters
Quoted: 0 Post(s)
Do what the manual tells you to dooooo. The manual is all knowingggggg.
Honda Scoots Galore
post #14 of 85 Old 10-22-2010, 08:33 PM
Turbo Snail
Perkins's Avatar
Quoted: 6 Post(s)
my manual says to use 5w30 or 10w30. I run 10w30 during the summer time and 5w30 in the winter.
My oil cap on my 95 says 10w30 and my 92 and 93 just say OIL FILL or something like that
If you are running 10w30 during the winter something to look into would be an engine block heater. It hooks onto your oilpan magnetically and heats your oil pan so when you start your vehicle, your oil is already thinned out and has good circulation right off the bat. Just dont forget to unplug it!
LoL
Perkins is offline
post #15 of 85 Old 10-22-2010, 10:01 PM
Senior TN Member
Quoted: 2 Post(s)
Just use a full synthetic and don't worry about the oil weigh. 0w20, 5w20, 0w30, 5w30, 10w30, 0w40, 5w40, 10w40...... all will work well and have worked great for me. I've even run 15w50 during our northeast cold winter.
5w30 and 10w30 are the same viscosity range at normal running temp. 30 falls between 9.3-12.5cst at 100c.
5w is tested at -30c(cranking) and -35c(pumping)
10w is tested at -25c and -30c...
25w is test at -10c and -15c
How cold does it get where you live?
If you don't live in the Santa household, quit worrying.
Because the 1997-2001 engines are sludge monsters(caused by cooking oil), I recommend that you use a full synthetic, check the oil every 500 miles, top off as needed, and keep the oil change interval reasonable. As long as the oil is full synthetic, I could care less what your oil weight is or what the owners manual recommends.
From Mobil1's website:
5w30 is 11.1cst
10w30 is 10.7cst
Higher number is thicker so which is???
And even more extreme, Castrol syntec:
0w30 is 12.1cst
10w30 is 10.1cst
Again, which is thicker?
Pennzoil Ultra:
5w30 10.3cst
10w30 10.3cst
Same!!!!
deadrx7conv is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
