94 Camry V6 Auto Shift Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 5 Old 11-12-2010, 10:19 PM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
Just had trans rebuilt by national trans company. Have most of the same problems after rebuild as before:
-Start on cool/cold day, no upshift into second until a screaming 4,000 rpm or higher. A manual shift into second gear is possible. When temp gauge needle is mid to top of letter C trans shifts into second gear at 3,300 rpm
-Hard shift from first to second gear
Will the eng temp sensor and or the throttle position sensor be at work here?
dickb is offline
post #2 of 5 Old 11-12-2010, 11:03 PM
イリジウム
Quoted: 364 Post(s)
Sounds like they took your money without really solving your problem.
If the transmission is working like it should, I would check the throttle linkage. It modifies ATF main line pressure according to throttle position. But it would be a surprise if the "national" transmission company didn't do this. 3300-4000 before going into 2nd is too high.
Another thing is to check the activation of the correct solenoids at the proper times. But a good shop should have done this too on their dyno.
It's another reason I would go to an ATRA (Automatic Transmission Rebuilders Assoc) shop, and not a fast lube place or a "national" transmission shop for example.
JohnGD is offline
The Following User Says Thank You to JohnGD For This Useful Post:
dickb (11-12-2010)
post #3 of 5 Old 11-12-2010, 11:12 PM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
Thanks John. What is the spec for the adjustment?
dickb is offline
post #4 of 5 Old 11-12-2010, 11:25 PM
イリジウム
Quoted: 364 Post(s)
The throttle linkage on the throttle body end has a staked stopper on the cable. The stopper should be 0-1mm out of the rubber boot.
Check repair manual, Haynes or Autozone's free repair guide. There were discussions on TN too. Here is an example:
Engine Swap Now Tranny Doesn't Shift
JohnGD is offline
dickb (11-12-2010)
post #5 of 5 Old 11-12-2010, 11:44 PM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
John I visited the link you provided. I also found this < http://www.**********s.com/camry/ax2.pdf > On page AX2-69 are instructions to adj cable. Reading both is confusing. I will do as explained on AX2-69 but first stressing the cable by fully depressing the accelerator pedal, then checking the distance between the outer cable end and stopper on the cable. I will do that in the morning. Thanks again. The missing letters are turbo and ninja
dickb is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
Tags
camry 1994 , sensor , shift , transmission
User Tag List
Linear Mode Linear Mode
Back
