99 camry 4cyl P0171 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 8 Old 02-04-2011, 08:22 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
99 camry 4cyl P0171
I pulled a code this morning from my 99 camry le and it was P0171 "system too lean bank 1". Any ideas of where to start troubleshooting?
chazdiezal is offline
post #2 of 8 Old 02-04-2011, 09:29 AM
Senior TN Member
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Quoted: 4 Post(s)
Has anything been done to it recently? Start with the air filter box and make sure it's properly installed and not leaking. Then follow the large intake hose and check for cracks or leaks and do the same for all air/vacuum hoses.
It worked fine until I fixed it!
csaxon is offline
post #3 of 8 Old 02-04-2011, 09:30 AM
Senior TN Member
Quoted: 4 Post(s)
Any other codes?
csaxon is offline
post #4 of 8 Old 02-04-2011, 09:36 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I've recently had sparks, wires, and pcv valve changed. I also wanted to get the fuel filter changed but the guy said he couldn't get the old filter off.
post #5 of 8 Old 02-04-2011, 09:37 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
There are no other codes showing.
post #6 of 8 Old 02-04-2011, 10:00 AM
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Quoted: 5 Post(s)
iTrader Score: 13 reviews
Email sent with some info.
Gary Smith-Parts Manager
TOYOPARTSMAN is offline
post #7 of 8 Old 02-04-2011, 10:04 AM
Senior TN Member
Quoted: 4 Post(s)
csaxon is offline
post #8 of 8 Old 02-04-2011, 10:11 AM
Senior TN Member
Quoted: 4 Post(s)
Your mechanic may have removed the air box to get to the fuel filter and not put it together properly.
Possible causes:
Air intake (hose loose)
Fuel line pressure
Injector blockage
Heated oxygen sensor (bank 1 sensor 1)
Manifold absolute pressure sensor
Engine coolant temp. sensor
Also, look at your fuel filter and see if the mechanic used brute force and twisted the fuel line; reducing fuel flow.
csaxon is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
