Double DIY: Replace your ECU/Remove your glovebox - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 38 Old 03-28-2011, 07:34 PM Thread Starter
Chris Crash's Avatar
Quoted: 30 Post(s)
iTrader Score: 13 reviews
(Thread Starter)
4th Generation Double DIY: Replace your ECU/Remove your glovebox
I needed to (hopefully) replace my ECU so I wanted to show people how to get to it. Also, people ask a lot how to remove the glovebox so it's a double DIY.
Tools:
  • 10 mm socket
  • Socket Wrench + extensions
  • Phillips head screwdriver
Time Required:
  • 20 minutes if you're competent
DISCLAIMER: The work you are about to complete is to be done at YOUR OWN RISK. You are dealing with dangerous and sensitive electrical equipment that can hurt you but also damage and destroy your car. Do not attempt this DIY if you do not feel you can handle it.
  1. Disconnect the battery. There's a slim chance you'll need to do this, but it's still a chance. Just do it.
  2. Grab onto this plastic trim piece running along the door and pull towards you. It will snap right out.
  3. Remove the black plastic screw that would normally be right here.
  4. Grab onto this plastic trim piece covering the junction block and pull towards the drivers side. It will snap right out.
  5. Grab onto this plastic trim piece going along side the glovebox and pull towards you. It will snap right out.
  6. Remove this 10 mm screw. It strips easily so I recommend not using a screwdriver on it.
  7. Open the glovebox and remove the three screws along the top of the door pictured here.
  8. There is another screw (not pictured) on the lower left corner of the glovebox to be removed. It's also a phillips head.
  9. Pull the glovebox door down and out towards you in a quick motion and it will snap out.
  10. Now you can see the ECU and all it's wiring. Disconnect the three big white connectors going to the ECU.
  11. Remove this 10 mm nut on the top bracket of the ECU.
  12. Remove this 10 mm nut on the bottom bracket of the ECU.
  13. Rotate and twist the ECU until you get it out. Hint: it comes out the bottom.
  14. Swap the brackets from the old ECU to the new ECU.
  15. Re-install. It takes a lot of twisting to get it back in position. You'll need to be somewhat of a contortionist.
  16. Re-installation is the reverse of disassembly.
Note: The ECU will have to re-learn the correct idle speed, so for the first few minutes the idle will be a lot higher than it should be. This is normal and fixes itself with normal driving.
2016 Toyota Corolla S Plus 6-speed
2015 Dodge Ram 1500
1997 Toyota Camry LE 5-speed
1994 Toyota Camry J-Vin
1997 Toyota Camry CE 5-speed
Chris Crash is offline
The Following 5 Users Say Thank You to Chris Crash For This Useful Post:
ahnic (03-17-2013), houra (11-18-2011), O_loung1 (05-25-2012), shockley (09-01-2012)
post #2 of 38 Old 03-28-2011, 11:21 PM
Quoted: 0 Post(s)
nice diy and write up. very good pictures. will be helpful for the community. sticky
2000 Toyota Camry LE V6 IMZFE
ty**20 is offline
post #3 of 38 Old 03-28-2011, 11:33 PM
The Tri-Camry Family
Yuko's Avatar
Quoted: 14 Post(s)
Thanks for the DIY. I never knew there the ECU was located, learn something new. I never had an ECU failed but what can cause it?
"Yūko" 2001 Camry 5S-FE/A140E @ 130k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 180k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 80K
Yuko is offline
post #4 of 38 Old 03-28-2011, 11:51 PM Thread Starter
Quoted: 30 Post(s)
(Thread Starter)
I'm not sure what exactly causes it, but symptom for me was a CEL that would not go away. Ever. haha after replacing every other component twice...it was down to the ECU.
I'm not POSITIVE here about how they work, but at least for knock sensor's there's a switch in the ECU that does something when it's malfunctioning, so I'm guessing letting the problem stay for so long left the switch on (or off) constantly and it fried it? and therefore even after the problem was successfully fixed, the ECU didn't see the improvement.
2015 Dodge Ram 1500
post #5 of 38 Old 03-29-2011, 10:35 PM
Freakin Scooters
LynchburgCSI's Avatar
Quoted: 0 Post(s)
iTrader Score: 16 reviews
Andddd stuck.
Honda Scoots Galore
LynchburgCSI is offline
post #6 of 38 Old 11-17-2011, 01:55 PM
Quoted: 0 Post(s)
Where did you get your replacement ECM? Or does anyone have a recommendation of a reliable ECM dealer. I can not have car down while I wait for an ECM to be rebuilt. Thanks for the DIY.
medic2u is offline
post #7 of 38 Old 11-17-2011, 03:22 PM Thread Starter
Quoted: 30 Post(s)
(Thread Starter)
www.car-parts.com
2015 Dodge Ram 1500
post #8 of 38 Old 11-17-2011, 03:22 PM Thread Starter
Quoted: 30 Post(s)
(Thread Starter)
However if you're looking for a 5SFE M/T ECU, I have one for sale.
2015 Dodge Ram 1500
post #9 of 38 Old 02-10-2012, 10:38 PM
Quoted: 0 Post(s)
is the 5s for the I4? and will it need to be programmed for a 96 camry 2.2? Thank you
DrDreams is offline
post #10 of 38 Old 02-11-2012, 01:06 AM Thread Starter
Quoted: 30 Post(s)
(Thread Starter)
The 5SFE is the 4-cylinder engine.
2015 Dodge Ram 1500
post #11 of 38 Old 02-11-2012, 03:28 AM
Quoted: 0 Post(s)
Cool. Thanks for clearing that up. Do I need to program it? If I am pulling it off of another car
DrDreams is offline
post #12 of 38 Old 02-11-2012, 07:09 AM Thread Starter
Quoted: 30 Post(s)
(Thread Starter)
As long as it's the same transmission, engine, and generation you'll be ok. So for a 96 you'll want to pull it off a 94-96 year car with your same engine and transmission. Also cruise control matters too.
2015 Dodge Ram 1500
post #13 of 38 Old 02-11-2012, 08:44 AM
Quoted: 1 Post(s)
4th Generation
So, did it finally resolve your CEL problem??
99 Camry (141k miles-At the graveyard now!)
99 Camry (215k miles)
02 Sienna (217k miles)
dave1811 is offline
post #14 of 38 Old 02-11-2012, 03:46 PM
Senior TN Member
Quoted: 26 Post(s)
gah I hate you chris >.< factory amp >.< I've been trying to find one at the junk yard with the harness to see if it would work with my factory stereo, since I have an extra plug that I don't use.
This is a pic of my radio from ebay but its the bottom left plug that I have open, maybe you can tell me if its the correct plug
adalex is offline
post #15 of 38 Old 05-22-2012, 09:26 PM
Quoted: 0 Post(s)
quick question on ECM
What signs indicated bad ECM? My speedometer needle drops to zero and it seems like it drops a gear at times cause the rpms increase.
camry786 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
Tags
box , cel , diy , ecu , glove
User Tag List
Linear Mode Linear Mode
Back
