EFI fuse problem - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 5 Old 05-04-2011, 12:33 AM Thread Starter
deejayphilo's Avatar
Quoted: 0 Post(s)
(Thread Starter)
EFI fuse problem
Any idea why my car keep popping the EFI fuse. I thought I put the wrong ampere but nope I got the right one 15 amp...as soon as I put it pop right after I switch the ignition. Before it works when when I change the fuse but now it keep popping as soon as I change it and switch it on.
deejayphilo is offline
post #2 of 5 Old 05-04-2011, 11:30 AM
Do you feel lucky?
TrailDust's Avatar
Quoted: 3909 Post(s)
This is a common issue with Toyotas, and here's a past thread that discusses it. The EFI fuse often blows because there is a short to ground in the red/white wire that supplies power to the injectors and the O2 sensors as well as a lot of other components. Check the B+ terminal to see if it's shorted to ground. Disconnect the battery and use an ohm meter between the B+ terminal and body ground.
BTW, you may also want to do a Google search for "efi fuse blowing" and it'll turn up lots of information. Good luck!
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline
post #3 of 5 Old 05-04-2011, 02:13 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Yah i check the grounded i even added some grounds maybe it might help but still blowing fuses after fuses.
post #4 of 5 Old 05-04-2011, 06:07 PM
Senior TN Member
Quoted: 86 Post(s)
+1 On the wiring harness for your fuel injectors. I've had it happen myself. It may start out just blowing the fuse randomly, but as the point it is occassionaly touching and shorting at gets more worn, at some point it will just weld itself closed. Could be happening anywhere on the harness or even inside it.
Silent Runner is offline
post #5 of 5 Old 05-04-2011, 10:45 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I will remove the injector wires maybe splice the whole wire and get a new set from my spare camry engine here and see if it is the same....
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
