What type of transmission fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 8 Old 07-18-2011, 07:45 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
4th Generation What type of transmission fluid?
What type of transmission fluid do you use for 2001 toyota camry 4 cy?
Thank you for your help Anne.
bettiepug is offline
post #2 of 8 Old 07-18-2011, 07:55 PM
イリジウム
Quoted: 298 Post(s)
If you have Advance Auto nearby use Mobil-1 fully synthetic ATF using their discount coupon code. You should come close to $5.50 or so per quart depending on the discount.
Next tier are the Walmart SuperTech Mercon-V just under $4 and Castrol Import Multi-vehicles ATF just under $5. (you can see the advantage of using Mobil-1 at these prices).
Then it's the plain dino fluid, for example, the under-$3 SuperTech ATF. If you buy 1 gallon jugs each gallon is under $10.
All are Dexron-III type compatible.
JohnGD is offline
post #3 of 8 Old 07-18-2011, 09:29 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
4th Generation
post #4 of 8 Old 07-18-2011, 09:37 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thank you John I will use Mobil-1 fully synthetic ATF from Advance Auto and use their discount coupon. Is this the right coupon code BIG25? Anne
post #5 of 8 Old 07-19-2011, 11:49 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 9 Post(s)
I keep this listing handy, hope it helps, discount codes for online ordering in brackets
list is kinda old, and since then AAP jacked up the price of Mobil1 ATF to $9.59 (used to be $8.20 !!)
Mobil1 Dex/Merc ATF $9.19/qt @ Advance Auto
7qts @ $5.62/qt (BIG25)
6qts @ $5.85/qt (A123)
5qts @ $6.19/qt (BIG15)
4qts @ $6.69/qt (BIG10)
2qts @ $6.69/qt (BIG5)
'02 Solara SLE V6 1MZ-FE/A541E@ 154k
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
fenixus is offline
post #6 of 8 Old 07-20-2011, 01:18 AM
イリジウム
Quoted: 298 Post(s)
That's great. The closest Advance to Calif is in Colorado. Oh well.
JohnGD is offline
post #7 of 8 Old 07-20-2011, 01:29 AM
The Tri-Camry Family
Yuko's Avatar
Quoted: 14 Post(s)
Does synthetic ATF make a different in shift quality compare to regular ATF or is it just for fluid durability? This is making wish I filled my transmission and diff with synthetic, but I got Valvoline Dex/Merc for $2.50 a bottle so I shouldn't really complain.
"Yūko" 2001 Camry 5S-FE/A140E @ 130k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 180k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 80K
Yuko is online now
post #8 of 8 Old 07-20-2011, 01:43 AM
イリジウム
Quoted: 298 Post(s)
The synthetic fluid should maintain the shift quality longer and hold up against heat better. But initially they should both be the same. I'd still change the fluid every 10-15K miles because the A-series is kinda dirty unless you have a Magnefine on there they the fluid will probably stay red for a longer period of time.
You can try Mobil-1 or SuperTech Mercon-V that's suitable for D-III at least in the differential. The ST Mercon-V is about $3.90/qt so not a real advantage for those who can by Mobil-1 for a little more.
JohnGD is offline
The Following User Says Thank You to JohnGD For This Useful Post:
Yuko (07-20-2011)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
