Timing belt replaced, now will not turn. - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 5 Old 08-02-2012, 01:43 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
94 Camry 2.2 4 cylinder, I replaced the timing belt, no other problems with the car the just time to replace the timing belt. My manual disapered just before I went to do the job. Most everything went fine except when I went to start the car. It would not start and was clearly out of time. I retimed it and now the engine will not rotate. It will turn sofar and then it stops. I understand this is a non-interference engine so what could be the problem be? How can I see what is going on in that engine with out pulling the head off of it. How do I determine which cylinder it is?
greyheadedguy is offline
post #2 of 5 Old 08-02-2012, 03:18 PM
Quoted: 0 Post(s)
Recheck all your work.
When you rotate the engine is this coming to a dead stop or are you just encountering strong resistance? Are you rotating the engine with spark plugs in? Rotating the engine with the spark plugs in will meet with resistance due to compression. You overcome this compression by applying more torque to the wrench. Pull all the spark plugs out and rotate the crank and you can look down the spark plugs holes and you should be able see piston movement.
hzt30 is offline
post #3 of 5 Old 08-02-2012, 08:19 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
I had the spark plugs out when I did this. I understand engine compression, that is why I removed the spark plugs. The engine came to a dead stop like there was either something in the cylinder or some other interference stopping the movement.
Is there anyway that it dropped a valve or something. My worse fear is that a neighbor;s kid dropped something in the engine. That is the only way I can figure I would have any interference in the engine, unless somebody knows something I don't ( Which would not surprise me.)
post #4 of 5 Old 08-02-2012, 08:26 PM
Toyota Collector
71Corolla's Avatar
Quoted: 1384 Post(s)
Is the timing belt binding up on something? Remove the belt and turn the crank and cam independently to find out where the problem is.
2000 Lexus ES300 Millenium Edition
1990 Camry LE V6 Anniversary Edition 5-Speed
1990 Camry LE V6
1990 Camry LE V6 WAGON
1987 Camry LE I4 5-Speed
71Corolla is offline
post #5 of 5 Old 08-03-2012, 07:20 AM
Quoted: 0 Post(s)
Highly unlikely a valve would just drop.
Do as 71 Corolla suggested and remove the timing belt and see if the crank turns.
hzt30 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
