02 Sensor Removal Horror! - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 19 Old 11-12-2012, 03:57 PM Thread Starter
Noob
Quoted: 0 Post(s)
(Thread Starter)
Hey guys. So I know this is a car-world wide problem and what not but I have never had this experience with any other car i have ever had! I am relatively a novice when it comes to engine work and what not but I like to fix whatever I can instead of paying hundreds for the same type of work. Recently I have decided to change my 02 sensors since im at 140k which is about that time. I got about 2 and a half rotations in when it seized on me and its been a battle ever since . I can get about a half rotation from it but anything else its stuck.Any or suggestions from anyone? ...BTW i have a 1998 Camry V6.
REYJAYY is offline
post #2 of 19 Old 11-12-2012, 04:02 PM
Senior TN Member
Quoted: 0 Post(s)
Will it tighten back in? If so just keep tightening it, loosening it, tighten, loosen. You might get it a little looser each time.
If not
More blaster?
Heat?
Let blaster soak?
1995 Chevrolet 1/2ton ext cab 4x4 6.5l Turbo Diesel
1998 Toyota Camry 5SFE Auto
2002 Chevrolet Impala
1997 Nissan Pathfinder 4x4
bolink654 is offline
post #3 of 19 Old 11-12-2012, 04:05 PM Thread Starter
Noob
Quoted: 0 Post(s)
(Thread Starter)
If not
More blaster?
Heat?
Let blaster soak?
yea I tried the the loosen tighten method but it wont tighten all the way either. It seems like its just stuck between two threads. I have soaked it with the pb blaster for the last two days with no results. I think my last resort would be heating it up with a torch because i tried with just the engine heat with no success at all
REYJAYY is offline
post #4 of 19 Old 11-12-2012, 04:07 PM Thread Starter
Noob
Quoted: 0 Post(s)
(Thread Starter)
at this point to the bolt is pretty much stripped. I started with the 02 sensor socket and a breaker bar and now my only option is vice grips smh
REYJAYY is offline
post #5 of 19 Old 11-12-2012, 04:11 PM
Zac
Quoted: 1 Post(s)
I'd heat it. A propane torch probably won't be enough though. Cherry red with an oxy acetylene though, and I think it'll come right.
'93 V6 Sedan. Stock.
ZAchole is offline
The Following User Says Thank You to ZAchole For This Useful Post:
REYJAYY (11-12-2012)
post #6 of 19 Old 11-12-2012, 04:21 PM Thread Starter
Noob
Quoted: 0 Post(s)
(Thread Starter)
I have more access to a propane one than and oxy and really dont have alot of money to spend (only 22 with a crappy full time job in nyc) so my options are limited but I def will try this
Question though....When applying heat what is my best option for heating it without getting any heat transferred to the sensor itself?...Wont the sensor also expand with the hole?
REYJAYY is offline
post #7 of 19 Old 11-12-2012, 04:37 PM
Stilkiboy
Quoted: 4 Post(s)
It won't expand as much as the hole. But you could soak the sensor with the blaster. It will produce heavy smoke, but won't catch on fire(try not to inhale the smoke). This should cool down the sensor enough to loosen it.
-98 Camry 2.2 5S-FE
-96 Carina E 1.8 7A-FE
-96 Carina E 1.6 4A-FE
-85 Suzuki SJ 413 G13A (FK-Balja)
-86 Suzuki SJ 413 G13A
-84 Suzuki SJ 410 F10A
Dotsetsveen is offline
post #8 of 19 Old 11-12-2012, 04:40 PM Thread Starter
Noob
Quoted: 0 Post(s)
(Thread Starter)
Im definitely going to try this tommorow and let u guys know how it goes.Thanks for all the advice though!
REYJAYY is offline
post #9 of 19 Old 11-12-2012, 08:35 PM
Zac
Quoted: 1 Post(s)
I forgot about the fire and ice trick. I've used that many times.
ZAchole is offline
post #10 of 19 Old 11-12-2012, 10:48 PM
VVT-1MZ + ES5spd
Bdub215's Avatar
Quoted: 9 Post(s)
Just the Breaker Bar? No cheater pipe for extra support or anything??
as for an idea to get it off, see if you can weld a socket to that sensor, get a cheater bar + Breaker bar and that turn that thing out. Something should give at that point.
93 Lexus ES300 5spd I/E URFSB URRSB
01 Toyota Avalon TFSB, Weapon-R, Whiteline, Fogs
Bdub215 is offline
post #11 of 19 Old 11-13-2012, 12:41 AM
Quoted: 4 Post(s)
Remember to use some anti-seizing compound on the threads when you install the new one. That will prevent this from happening again. :gewd:
_______________________
Tockico Struts
18" Enkei NT03 Racing Series | WR Rally Blue Paint
Weapon R Dragon Intake
Pandalizer is offline
post #12 of 19 Old 11-13-2012, 01:08 PM
zzyzzx's Avatar
Quoted: 137 Post(s)
Last time I had this happen (and not to an O2 sensor socket) I ended up using a large pipe wrench to remove it. If you have enough room to use one, it was the only thing I had that could actually grip the thing good. If removing the manifold is an option (and it will be at some point) then you will definitely have the room at that point.
zzyzzx is offline
post #13 of 19 Old 11-16-2012, 02:31 PM
Daijoubu's Avatar
Quoted: 37 Post(s)
Try the famous ATF/acetone mix, works miles better than PB Blaster or try Liquid Wrench/Kano Kroil
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
Daijoubu is offline
post #14 of 19 Old 11-16-2012, 03:17 PM
Quoted: 11 Post(s)
Try bringing the car up to operating temperature then try and remove the sensor. Works for me.
Saw that ATF/acetone post years ago on the bobistheoilguy.com forum.
Here was the intro.
The April/May 2007 edition of Machinist's Workshop did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for simple acetone and tranny fluid!
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
2000 Camry IL4 5S-FE 100,000mi or 171,000km
Brit101 is offline
post #15 of 19 Old 11-16-2012, 04:38 PM
Asks many questions .....
LE PEW's Avatar
Quoted: 0 Post(s)
Originally Posted by Brit101 View Post
Saw that ATF/acetone post years ago on the bobistheoilguy.com forum. Mighty interesting results for simple acetone and tranny fluid!
I've never heard of that combo used as a penetrating fluid before. Is it used in equal parts?
BTW, I've used Kano Laboratories SiliKroil with great results in the past.
1994 Camry LE V6 156,000 miles
1995 Camry XLE V6 81,000 miles
LE PEW is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
« Back
