o2 sensor locations - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 9 Old 11-19-2012, 08:40 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
o2 sensor locations
I have been needing to replace a post cat o2 sensor for a while now, and finally im getting too it. Problem is i cant figure out where it is... the mechanic just said it was the lower sensor, so i ordered a new denso.
When i jacked up the car i looked where the manual said to check , read some posts on TN and still nothing (under driver and passenger side) am i just missing it? or does my car not have a sensor underneath?
this is the image i have been referencing on TN
this is my car and the only sensors i can find. heatshield has been removed, and i began to lube in anticipation of changing it, but then i came to my senses and figured someone would be able to help
thanks in advance
1996 toyo camry LE 4cyl
Lummpy5 is offline
post #2 of 9 Old 11-19-2012, 08:52 PM
Quoted: 0 Post(s)
Hmm, is it 4th or 3rd gen Camry?
russki91 is offline
post #3 of 9 Old 11-19-2012, 09:06 PM
Senior TN Member
Quoted: 5 Post(s)
That massive piece of iron between the two O2 sensors is your cataylic converter. The O2 sensor you have pictured with penetrating oil on it is your post-catalytic converter O2 sensor.
93celicaconv is offline
post #4 of 9 Old 11-19-2012, 09:06 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
not to sound silly... how do i find out? I have always just used year etc. to find info
Lummpy5 is offline
post #5 of 9 Old 11-19-2012, 09:14 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
excellent thank you. So is their no sensor underneath my car?
Lummpy5 is offline
post #6 of 9 Old 11-19-2012, 09:38 PM
Senior TN Member
Quoted: 5 Post(s)
To whom or what are you asking this question to? To my response back on where your post-cat O2 sensor is located? Really?
Well, here is a pic that I sure hope convinces you.
The Following User Says Thank You to 93celicaconv For This Useful Post:
Lummpy5 (11-19-2012)
post #7 of 9 Old 11-19-2012, 09:40 PM
Senior TN Member
Quoted: 5 Post(s)
Not underneath a 4-cylinder 5S-FE engined car, no. For a 1MZ-FE V6 engine, there would be an O2 sensor under such a car, as the catalytic converter is located between the front seats underneath the car, not by the radiator as the 5S-FE's location is.
post #8 of 9 Old 11-19-2012, 09:48 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
thanks, everything i was reading was contrary to what i was seeing. And being that the sensors are not exactly cheap i really did not want to replace the wrong one ( if their were multiple )
thanks again
no that was in response to russki
Lummpy5 is offline
post #9 of 9 Old 11-19-2012, 09:52 PM
Senior TN Member
Quoted: 5 Post(s)
No problem. You can't replace the wrong one in this particular setup. The post-Cat O2 sensor screws into the exhaust pipe. The pre-Cat O2 sensor is flanged with two bolts holding the flange in place. You can't put the right O2 sensor in the wrong location on this particular setup.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
