power window - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2003. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 19 Old 02-01-2013, 09:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
power window
I own a 2000 Solara v6 with 160,000 miles on it. I just finished the job of timing belt, water pump, tensioner and idler, cam and crank seals, valve cover gaskets (whew) spark plugs and spark plug boot seals in valve cover. The car runs great. I ever replaced the upstream oxygen sensors after a code was set. That fixed that problem. Now I am having problems with the driver side power window. About four years ago I could not get the window to work at all. I removed the door panel and was beginning to remove the window motor and for some reason it started working again. No problem since that day until yesterday. Now it tries to come up but the only way is I have to grab it with my hand and get it started. Same thing when lowering it. I can hear something slipping it seems. Any tips on what might be going on before I remove the panel to look. The window motor looked like a pain to replace but I can do that job if thats what I find is the problem. Thanks for any tips before I tear into it. fourputt
fourputt is offline
post #2 of 19 Old 02-01-2013, 10:52 PM
Quoted: 98 Post(s)
iTrader Score: 16 reviews
It could also be the regulator, but I;m going to guess the motor. Have you noticed it going up/down slower then normal lately?
My Camry: http://www.cardomain.com/ride/228043...y-xle-sedan-4d
'96 Camry: 2MZ
'95 AE101: JDM Tails/Grill/BiXenon Headlights. JDM Lighted Ignition Keyring and Cabin Air Filter
ASG14 is offline
post #3 of 19 Old 02-02-2013, 06:54 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I can just hear the motor spinning and the window will not move. I can tak my hand and give it a pull and it will come on up. Do you know how much of a job it is to replace the regulator? I wonder what is slipping? to cause this. I will try and remove the panel next week and maybe can see more of whats happening. Thanks.
fourputt is offline
post #4 of 19 Old 02-02-2013, 07:29 AM
Senior TN Member
Quoted: 26 Post(s)
Re: power window
Its not too bad, I recently did my rear passenger side and it was doing the samething as yours, just spinning. And I'd seen guides but I just pretty much figured it out as I went a long, uh make sure you get painters tape to hold the window up, because it tends to fall after u take out the bolts that go through the window :-P
Sent from my SAMSUNG-SGH-I897 using AutoGuide.Com Free App
If you find my post helpful, please use the button
adalex is offline
post #5 of 19 Old 02-03-2013, 11:13 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA
adalex
Did you replace the motor or regulator? I seen power window motors listed at rockauto but not the regulators. I am guessing the window motor is bad but will wait and see what you said you replaced. Thanks. fourputt
fourputt is offline
post #6 of 19 Old 02-04-2013, 12:04 AM
Senior TN Member
Quoted: 26 Post(s)
Re: power window
It was both, the car I got it from was a 97 or 98. The design was a little different ie one of the holes, on mine it was like a nipple but the one I got was a tube with a hole in the middle but everything lined up and it actually works just as well as the year old rear driverside that was replaced last year with a new OEM one from the dealership. I have pics and ill post them tomorrow
adalex is offline
post #7 of 19 Old 02-04-2013, 05:04 PM
grayling953's Avatar
Quoted: 0 Post(s)
Tip about replacing the regulator. Replace the whole assembly! you can try to do just the motor but it's very risky, because if the cable unwraps from the pulley while its off the motor, you'll never get it back on. Also, be careful where you order from. The dealership wanted $300+ for one regulator, so i bought a $40 one online. After a few months, it went bad again. So make sure you get a quality, full assembly. The job is really easy though.
grayling953 is offline
post #8 of 19 Old 02-04-2013, 06:09 PM
Turbo Snail
Perkins's Avatar
Quoted: 6 Post(s)
iTrader Score: 8 reviews
on my 99 camry, there are no cables for the regulator. Its gear driven, so only replacing the motor is required. on the 3rd gen camrys, its easier to just replace the entire regulator assembly
Perkins is offline
post #9 of 19 Old 02-04-2013, 10:45 PM
Quoted: 0 Post(s)
My bad, ive only owned gen 3's
post #10 of 19 Old 02-05-2013, 07:52 PM
TC01's Avatar
Quoted: 12 Post(s)
USA
I replaced the motor and regulator on my wife's 96 Camry drivers side. I ordered it from Amazon and it came as one unit. All I did was remove the door panel, unplug the motor, and unscrew the bolts holding the regulator to the door frame. Installation was just in reverse. It took me about 30 minutes. It's been working fine ever since. The whole assembly (motor & regulator) cost me $67.
1996 Camry LE - 6 Cyl 1MZ-FE 177,000
2001 Camry LE - 4 Cyl 5S-FE 182,000
Both still going strong!
TC01 is offline
post #11 of 19 Old 02-05-2013, 09:03 PM
Senior TN Member
Quoted: 26 Post(s)
one thing i noticed in the new motor/regulator is that i saw how the broken one actually broke. the cog shaped thing that went through the regulator broke, but the replacement one i got was attached to the motor differently
adalex is offline
post #12 of 19 Old 02-05-2013, 09:09 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I am still not sure which one I need. I found this one on ebay
http://www.ebay.com/itm/TOYOTA-OEM-6...-/150965121214
The left motor is $78.99 at rockauto. I wonder why the right side is only $43.79 ??
Like I mentioned, the windows stopped working about 3 years ago. It would not do anything when I tried to raise or lower. I removed the door panel and after fooling around with it all of a sudden it started working and has worked perfect for 3 years now. It is not doing what it did 3 years ago. Now I can get it to come up by pulling with my hand. It sounds like something is slipping. I found a rebuilt motor at rockauto but again I am not sure which one I need. I wish I could find the complete unit. Thanks and any more tips appreciated. fourputt
fourputt is offline
post #13 of 19 Old 02-06-2013, 07:46 AM
Senior TN Member
Quoted: 26 Post(s)
Re: power window
Hey I just saw your location, where do u live?
adalex is offline
post #14 of 19 Old 02-06-2013, 06:51 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I live in Alabama. fourputt
fourputt is offline
post #15 of 19 Old 02-06-2013, 07:42 PM
Senior TN Member
Quoted: 26 Post(s)
oh ok, im down in tampa
adalex is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2003)
User Tag List
Linear Mode Linear Mode
Back
