So we all love to build our cars the way you want it to be . Ideas flourish through your mind and wanting to create something unique . So I have never saw Star Wars , I know I'm crazy . So I became a stormtrooper fanatic and love the black and white theme , haven't seen anyone build a stormtrooper theme camry!
So here where it all begins and there's more to come
Stock
Next step dipped the grill and lower grill
Now added a s204 Sti lip
Added a m3 sports lip
Next added some lip Kira from dura flex
New exhaust/muffler
Changed the center a bit
Got these in the mail (not installed yet )
Brand new grill from camry SE from Japan
HID lights , 8k on top 3k on bottom
Now got the shoes to be fitted and new Megan springs
BSA 321 18x8 et 40
Lol I got to lazy to find it and I wanted to make a more detailed thread . So new comers can have an idea of what parts I used. The radio controls and cruise and stuff . Either "A" ignore them. B - make some customer button switches . but I need a diagram for the horn . Anyone got that ?
Here's a new update
Out with the old in with the new .
Very nice work...creative and a successful "spiriting" of the Camry's conservative styling...I had considered doing something of the same...in the end I settled for just a "blacktop" ....not bad, but not "sporty" like yours.....
Do you mean the black plastic circle or clear plastic over the wire. If its the clear plastic tube, try to keep it but thats kind of a safety so that the positive wire does not touch ground and short something out/ burn/ cause a fire. If you cant keep it wrap it in electrical tape or buy a heat sink and it will help insulate the connection.
Car looks great. Im surprised I like the hood usually I don't like things like that. I would probably suggest getting the roof Painted black.
Okay that's fine . I'll prob shorted the plastic tube . So it can fit perfect so I don't cross thread the bolts . I'm thinking about painting the bolts . Any suggestions ? Or keep it how it is
Insert slim hub adaptor , since I didnt straighten my steering I marked where the steering wheel was place originally with a slim line so that's considered my center next time whoever is doing this straighten your steering wheel for you proceed. Don't make the same mistake I did.
Instead bolt . And tighten down with 25lb tq .
Install quick release , I did a star pattern for even placement .
There is no bulb, you have to take the cluster apart and unsolder the LED. As far as removing the cluster IIRC you just pull off the trim under the cluster and it like 2 screws at the bottom of the cluster. There is a sticky on replacing the LEDs, it is a different cluster but should give you the general idea on how the cluster comes apart. I think it will fail NC inspection just for not having the airbag installed. Not sure though just my 2 cents worth. http://www.toyotanation.com/forum/1...7-2011/311444-diy-instrument-cluster-led.html
