2005 camry le waterleak into cabin - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2005, 08:06 PM   #1 (permalink)
View ebiggs264's Photo Gallery
After 5 days of rain, I have lots of water on the driver side and some on the passenger side. It appears to have come in through under the dash, I think. I see the two drain holes under the hood in the corners, how do I clean these out? Any other drain holes or causes of the water leak I should look for? Thanks.
ebiggs264 is offline   Reply With Quote
Old 10-14-2005, 08:32 PM   #2 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
yes i found something out when wiring my amp and subs:
the grummet on the driver side where i pushed in the power wire was all wet. water leaks in from those grummets/holes that go into the engine bay. i told the dealer and they know about it, but wont bother telling you because they just dont give fu@% !!!. i siliconed it anyways to be safe but thats probably where its from, at least in my case.
johnnyzee is offline   Reply With Quote
Old 10-15-2005, 09:47 PM   #3 (permalink)
View lenjack's Photo Gallery
You clear the drains with a stick or coathanger..takes a few seconds.
lenjack is offline   Reply With Quote
