I know it cant be a true comparison because it's two different cars, weights, etc...
what im curious to see is how the power curves stack up.
consider this: The prius makes 295ft/lbs from 0-1200 rpm, where the gas engine is making practically nothing. the electric motor doesnt make that kind of torque up top though, but the gas engine is making more torque.
the result is a pretty flat torque curve across the entire power band. what I'm really interested in comparing is how the torque curves match up. I'd expect to see a much less steady torque curve for the camry, with less torque at the beginning and more dropoff at the end. Area under the curve is more imporatant than peak numbers in most cases, so I just need some type of general comparison.
As far as my report goes, I'm not just comparing them based on that, ithat would be a kind of apples to oranges comparison. it's more to show that hybrid power can make a solid case even without the strongest gas engine, because of the flexibility the torque curve provides.
