Originally Posted by majorgercko1
ok yes the cables were moved up, i still have a question though, i ve notives that the little black box makes some weird noises. when the projector turns on. It makes so squeaking noise like a beep sort of thing. is that normal, it does it when it gets connected to the battery and when i connectt it to the headlight harness.
Ok the little black box is the ballasts and the gray/ silver big box are the ignitors i believe. So the ballasts are making the noise.
SO they make noise. That is a good thing. That is normal (you should hear my denso ballasts, they scream). It is probably because most toyotas use a ground switched connector which may not be the correct match for the litronic. I have never worked with those ballasts before, so I am half guessing here.
Either was, a relay harness would be a good investment to protect your factory wiring harness... and it makes troubleshooting a whole lot easier. Here is a good tutorial:
http://jdmlyfestyle.com/hid_wiring_harness.htm
