CEL - P0446 !!! Help needed - Page 4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2006, 10:10 AM   #46 (permalink)
megamac83's Avatar
View megamac83's Photo Gallery
DOES ANYBODY KNOW ABOUT THE HOSES I'll need for the charcoal canister?
megamac83 is offline   Reply With Quote
Old 10-05-2006, 12:31 PM   #47 (permalink)
2006 Avalon XL
View sunny_8's Photo Gallery
Did you ever figure out what it was ?
2006 Avalon XL Blizzard
sunny_8 is offline   Reply With Quote
Old 04-15-2007, 09:06 AM   #48 (permalink)
Nunzie's Avatar
View Nunzie's Photo Gallery
Did you ever fix this????
Lexus IS300, 04 Sienna LE, 01 Avalon XLS
(sold) 99 Tacoma TRD ---- 86 SR5 Xtra cab, 35's w/8.5" lift
Nunzie is offline   Reply With Quote
Old 08-16-2007, 09:44 AM   #49 (permalink)
sls
View sls's Photo Gallery
Got it!
OK, here is my 446 story. I believe it has some value because I finally got it fixed. But it was not easy. Camry 99 I4, Toronto, Canada.
  • Check Engine light is on.
  • Went to my mechanic. He read the code P0446 (no other codes) and recommended to go to Toyota to get evap. emission system test to pinpoint the problem.
  • Went to Toyota and did the test ($100). The verdict - VSV valve on the charcoal canister.
  • Replaced VSV valve ($150) and rest computer. 20 km later the light is on again. After reading through this forum I was ready for this…
  • Back to Toyota. They ran the test and everything seems to be OK. Reset computer and said that it should help. 20 km later the light is on.
  • Toyota. Re-fit vacuum links, re-tested. 20 km later the light is on.
  • Toyota. Replaced vacuum links ($40). 20 km later the light is on.
  • Toyota. Re-fit vacuum links, replaces some other valves (no charge). 20 km later the light is on.
  • Toyota. Swap computer with one of mechanics just to exclude it. 20 km later the light is on. Computer is OK.
  • Toyota. Replaced charcoal canister ($400, gave me good discount, I’m paying only for parts) because there is nothing more to change. The promise was that if it wouldn’t help they wouldn’t charge me. But it helped, 1500km later the light is still off.
The bottom line. P0446 code is not a mystery, there is always a real problem behind it. But even with original Toyota diagnostic tools it’s very difficult to find the problematic element(s). Judging by what I’ve read about it, in 90% of cases it’s either one of the valves or the canister. It’s worth to deal with official Toyota because after initial diagnostics they did not charge me for labour at all, I believe otherwise there would be few thousands dollars of labour charges. Thank goodness the dealership is right across the street from my home And, of course, it’s a shame for Toyota to have such a poorly designed system so it cannot be diagnosed by official dealer!
sls is offline   Reply With Quote
Old 12-10-2007, 08:28 PM   #50 (permalink)
View quail's Photo Gallery
Originally Posted by trdcamrygracia View Post
i just replace the vsv and the CEL light up after few hours again....does any1 know wuts wrong....still show same code p0446
Where did you get the vsv?
quail is offline   Reply With Quote
CEL Mystery Mousiee Camry & Solara Lounge 0 10-05-2005 06:07 PM
CEL Light, Code P0441 and P0446 Hajoca Camry & Solara Lounge 2 07-27-2005 01:50 PM
cel 05 xrs mmartin1872 Archived Corolla threads 0 07-24-2005 09:34 PM
CEL 99 V6, Codes P0446 & P1135 Galvatron Camry & Solara Lounge 4 04-05-2005 06:17 PM
Cel P0446 Vsv? fe519 Camry & Solara Lounge 2 02-04-2005 11:21 AM
