Need help with my Gen 5 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2006, 04:40 AM   #1 (permalink)
View HungryWanksta's Photo Gallery
Gen5 Need help with my Gen 5 Camry
I bought and attempted to install doorsills that light up when the doors open, however they did not come with any instructions and when I attempted to connect the positive wire to the door switch it did not work. Of course I grounded the wire, I was wondering why there is only one wire coming from the door switch and where I could hook up the wires to the door sills will light up when I open the doors.
I also bought a aftermarket footlight kit off of eBay. It did not come with a switch, however I was told I could hard wire it. I attempted to do so but, the kit I believe is missing some wires so, I contacted the dealership and they said they could not help. Could anyone give this rookie some advice?
One more thing, lol. Has anyone found any cold air intakes for their Gen 5 4cyler Camry’s? I’m, not sure if getting the Injen or the Dragon Type R short ram intake is worth it.
-PCE
HungryWanksta is offline   Reply With Quote
Old 02-04-2006, 07:21 AM   #2 (permalink)
Import Fire Fighter
View theMANry's Photo Gallery
Gen5
-PCE
im not sure about the wiring. im ussually good at this stuff but id have to look at it to figure it out.
as far as cold air intakes, they dont make one. they do however make short ram intakes.
i got one for 100 bux shipped off ebay. i got this one: http://cgi.ebay.com/ebaymotors/02-03...temZ8033168981
i hope this helps and good luck
2008 Scion xB 5spd
AEM CAI - TRD Exhaust w/o Second cat -
-TRD 19's - Eibach Sportlines -
many other goodies
theMANry is offline   Reply With Quote
Old 02-04-2006, 08:18 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The door pin switches use a negative trigger. In other words you have it hooked up wrong.
Tie the positive lead to constant +12V. And the negative lead to the door pin switch or the door trigger wire (I have no idea where it is on a gen 5 though).
Door trigger wire is also negative trigger, but it outputs whenever any door is open. The door pin switches only work for the door its tied to.
Is there just 2 wires on the footlight kit?
"Skoolin' the unlearned!"
Old 02-04-2006, 03:41 PM   #4 (permalink)
thx, that makes since, i should have tried that before.
what would you guys recommend for a head unit for under 500?
Old 02-04-2006, 05:24 PM   #5 (permalink)
Dominican Republic
Dj-torn's Avatar
View Dj-torn's Photo Gallery
Head unit under $500 I say go with eclipse all the way.
Do you have pictures of the products, this might help make sense of things, also would give us something to look at.
As far as Intakes go, you will not get a SIGNIFICANT increase in HP according to most people on this forum, its been said that you will more than likely loose HP... But most people seem to agree that it does give the engine a nice sound... Conclusion, Let it be what suites your budget.
Stock 2002 Camry LE: 2AZ-FE: VVT-i
Dj-torn is offline   Reply With Quote
Old 02-04-2006, 06:33 PM   #6 (permalink)
Mr. Bigglesworth
iaussi's Avatar
View iaussi's Photo Gallery
Post up some pics of your installation
Could you post up some pics of the installation of the door sills and pics of the finished product. I want to see how it looks .
iaussi is offline   Reply With Quote
Old 02-04-2006, 08:22 PM   #7 (permalink)
obeycamgiant's Avatar
View obeycamgiant's Photo Gallery
That happened to me, got some el door sills from hong kong, and of course they give me no directions. and wondered how I was going to wire these. Ran two wires connected to (I think the red wire) on the dome light. Had them go down both of the center columns so I can hook up one side of the front and rear door sills. BECARE OF NOT BLOWING FUSE, accidently did that. Grounded one of the wires from the door sill transmittor and combined the three positive wires so they would turn on when the dome light would be on, and of course thats when and only the door opens. I have some pictures, Ill host them if I can still find them.
obeycamgiant is offline   Reply With Quote
Old 02-08-2006, 01:45 AM   #8 (permalink)
Gen5
when ever it gets warming i'll install them and take some pics. however, that might be a few months away. thx for the insight.
Old 02-08-2006, 02:00 AM   #9 (permalink)
Heres some pics of the install and day time pics. Sorry the install pics arn't the best and educational but Ill try and take some more to make it more tutorial and I should of took the finish product at night, to get the el blue light effect. but here you go anyways.
http://img.photobucket.com/albums/v4...1/IMG_0032.jpg
http://img.photobucket.com/albums/v4...1/IMG_0031.jpg
http://img.photobucket.com/albums/v4...1/IMG_0015.jpg
HIDING the wires down the center colums
http://img.photobucket.com/albums/v4...1/IMG_0014.jpg
http://img.photobucket.com/albums/v4...1/IMG_0013.jpg
Old 02-08-2006, 02:04 AM   #10 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $531607
iTrader Score: 7 reviews
View xpeed's Photo Gallery
I"m sorry, but those lighted sills are just too ricey for my taste. I only have chromed ones......though, I'm gonna rechange them again to the factory OEM ones.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 Neochromes - More on the way
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 02-08-2006, 02:15 AM   #11 (permalink)
your opinion is your opinion, atleast its not a brick of light glowing when you open the door, just the glowing camry letters. but atleat im not glowing led arrays of light all inside and underneath my car, now i believe thats where ricey starts. Now if they had comple door sills that went around on top and connected into the interior, id be all over them instead of the overlaping tape one ones
Old 02-08-2006, 03:20 AM   #12 (permalink)
View sportivo's Photo Gallery
obeycamgiant,
Looks like you have experience removing the B pillar. Can you tell me how difficult is it to remove it and some instructions please. Thanks
sportivo is offline   Reply With Quote
Old 02-08-2006, 09:59 AM   #13 (permalink)
toot toot ahhhh beep beep
View cuttooth's Photo Gallery
Super Kaioken had those sills too i think
'02 is300, eShift, LSD
'94 toy pickup, 22re, 5spd, xtra cab
cuttooth is offline   Reply With Quote
Old 02-08-2006, 10:36 AM   #14 (permalink)
Two Wheel Drifter
View spyman's Photo Gallery
I get nothing but compliments for my door sills, I also have the EL ones from hong kong.
I had a good mechanic install them, only problem is that one is burnt out so I have to replace it somehow. Also I guess some moisture got underneath all of them because I am noticing little rust spots. Oh well......
http://www.cardomain.com/id/spyman777
2002 "Soon to be a monster" Camry V6
2006 RAV4 V6
2006 Yamaha R6
spyman is offline   Reply With Quote
Old 02-08-2006, 02:21 PM   #15 (permalink)
yeah I noticed little rust stains underneath my stock door sills, but was able to just wipe it away. Sportivo, its really easy.---There are two parts of the pillar. the bottom one which connects into the top half of the pillar and also into the front and rear door sill by simply popping it out. After removing that, there are two interior screws on the bottom of the top pillar. Then whats left is just simply popping that part of that pannel out. Leaving the interior part of the pillar out. Hope this helps
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 11:55 PM
3rd gen camry --> 1st gen solara (suspension parts?) mox Solara 2 07-24-2004 09:05 PM
Australian(A-Spec) Gen 3 Camry Parts!!!! hittman 3rd & 4th Generation (1992–1996 & 1997–2001) 21 11-17-2002 01:03 AM
