2002 Camry V6 pulls to the left at speed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2006, 05:11 PM   #1 (permalink)
View marc780's Photo Gallery
My 02 Camry V6 pulls to the left at speed. I have to pressure the steering wheel to the right to make it go straight, needless to say this is annoying! I had the wheels aligned but this did not fix it. Has anybody else had to fix this problem?
Old 03-28-2006, 05:56 PM   #2 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Balance tires? Rims might not be 100% circular.
Try to make sure the PSI are the same and leveled out as well.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 03-28-2006, 06:26 PM   #3 (permalink)
View leasaunce's Photo Gallery
^ what he said.
balance all 4 wheels.
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 03-28-2006, 06:40 PM   #4 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908527
iTrader Score: 59 reviews
Take it back to the people who aligned it and tell them "It stills pulls to the left" Make them recheck it!!
I've gotten bad alignments by morons that didn't know how to use the technology that they have!
Bad wheels or balance would just make it ride rough!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 03-28-2006, 08:05 PM   #5 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
^^^ What he said.
V6LE_CAMRY is offline   Reply With Quote
Old 03-28-2006, 10:30 PM   #6 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
If its straight, def check the tire pressures especially in the front.
old faithful
amerikim is offline   Reply With Quote
Old 03-28-2006, 10:46 PM   #7 (permalink)
View Gary_602Z's Photo Gallery
It is not a balance problem! It could be alignment or a tire pressure problem or possible brake dragging though you should notice that at lower speeds to a certain extent.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 03-29-2006, 08:33 AM   #8 (permalink)
Moving Forward
View Cyorke's Photo Gallery
You could also have a bad tire. I used to work in a tire shop and we also used to see it at the dealerships I have worked at a lot. IF there is a bad belt in your tire it can cause the tire to cause a pull. IF you take it back and they check the alignment and it still pulls after them saying everything is fine ask them to rotate the tires and try it then. You can jsut take the two front tires and swap them. If the pull switches sides then it is more than likely a tire. if it stays the same then you have an alignment problem.
The bad thing is the caster and camber, which cause pulling normally, are not really adjustable on a Camry. There are kits that can be installed to make them adjustable but they are not from teh factory.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 03-29-2006, 08:43 AM   #9 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
just to sum up what others have said...
Check for equal tire pressure, equal treadwear, alignment, and balance if you feel the car vibrates at speeds of 50+mph.
Car pulling to one side does not indicate balance problem.
nodrogkam is offline   Reply With Quote
Old 03-29-2006, 09:43 AM   #10 (permalink)
Two Wheel Drifter
View spyman's Photo Gallery
I've dealt with alignment idiots with my 02...I have to go back again and get it done as I get it pulling right at speed both with my summer and winter rims.
http://www.cardomain.com/id/spyman777
2002 "Soon to be a monster" Camry V6
2006 RAV4 V6
2006 Yamaha R6
spyman is offline   Reply With Quote
Old 03-29-2006, 10:12 AM   #11 (permalink)
Moving Forward
One other thing to keep in mind is that most manufacturers build a little bit of left hand pull into cars. They do this because of the crown in most roads. This crown automatically causes the car to pull to the right so they build some left hand pull into it to compensate. SInce not all roads ahve this crown sometimes the left hand pull is much more noticeable.
NOt saying this is your problem at all but something to keep in mind.
Chris
Old 03-29-2006, 11:02 AM   #12 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
Sometimes a good alighment, and a good rotation and balancing can lead to car being pulled to one side...its called radial pull. Unfortunately, its now always broken belts, nor alignment issues or balancing. Sure placing certain wheel in the rear is good until its time for a rotation. My last set on the camry were suffering from this. THANKFULLY, i got all 4 radians this past weekend and it feels great!
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
For sale 1993 Camry SE 5 Speed with J spec V6 engine amg280 Vehicles 1 01-07-2011 11:12 AM
Looking for a 92-93 Camry v6 5 speed trd4life 3rd & 4th Generation (1992–1996 & 1997–2001) 2 07-19-2006 04:08 PM
Tire suggestions? Vaipunk Archived Corolla threads 11 03-11-2005 06:48 AM
Headlight Bulb upgrade for 2002 Camry LE V6 2002Camry 5th & 6th Generation (2002-2006 & 2007-2011) 9 09-19-2004 05:53 AM
