I just ordered one of these kits for my 2007 LE, and the install process seems pretty straight-forward, with one caveat: I'm not sure where to put the switch. I can't seem to find any blank switch plates in which to install them.
I apologize if this has been asked- any suggestions?
Here is what I would do:
Since the factory installed switches went in the trim panel between the shifter and the front console storage box, I would put them there. Hit a junk yard and get another trim piece in case you screw up you still have the original. Cut 2 rectangular holes one on the right and one on the left for the switches. Remember measure twice cut once. Cut the holes smaller than you need and use a small file for final fitting. Just my thoughts.
First pic is factory, second is my idea.
