2003 Camry LE Brake rotors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2006, 06:22 AM   #1 (permalink)
View Dylansdad's Photo Gallery
Gen5 2003 Camry LE Brake rotors
The last time I had my tires rotated and balanced I think they warped the brake rotors when they tightened things back up. I have 68,000 on the original brakes and now my steering wheel will shake when I apply the brakes. I am thinking of just going ahead and replacing the rotors and pads, I have done the pads on cars b4, but can someone tell me how difficult it is to pull and replace the rotors on this car ? Depending on the difficulty I may have them turned instead.......help...??
Dylansdad is offline   Reply With Quote
Old 04-03-2006, 09:01 AM   #2 (permalink)
Dave's
Gameroom cash: $121550
View Dave's's Photo Gallery
If they didn't turn your rotors then it's probably a bent wheel from improper torque. You MAY be able to loosen all the nuts and retorque properly.
Dave's is offline   Reply With Quote
Old 04-03-2006, 07:26 PM   #3 (permalink)
surely someone can tell me how easy or difficult it is to take rotors off this car...??
Old 04-03-2006, 08:13 PM   #4 (permalink)
View AJL0365's Photo Gallery
i remember on my car i had my brakes done and a rotation. the car would start to shake very violently dude test drove it and re-rotated my tires and balanced them, well one of my wheels were bent and it was up front so thats why it was shaking, he moved the wheel to the back and then it was all good from there, but then i bought new wheels anyways
AJL0365 is offline   Reply With Quote
Old 04-03-2006, 08:52 PM   #5 (permalink)
obeycamgiant's Avatar
View obeycamgiant's Photo Gallery
I have an 02 SE and to simply take off the rotor, you have you undo the caliper and its bracket. Then once that is off, easy two bolts to do, then you are able to remove the rotor. Then your able to easily remove the rotor off of the lug nut screws. Would say its too hard to do.
obeycamgiant is offline   Reply With Quote
INFO: 1996 Toyota Camry Specifications Ratko 3rd & 4th Generation (1992–1996 & 1997–2001) 22 08-08-2009 05:09 PM
Need help with CEL code P0354 on 2003 Camry LE needhelpwithcar 5th & 6th Generation (2002-2006 & 2007-2011) 2 10-01-2005 04:09 PM
Alpine CD Changer in 2003 Camry LE deltagundam Audio, Video, and Security - Tech 0 03-07-2005 10:42 AM
92-96 Camry LE V6 suspension- supposed to be firmer than 4-cylinder? 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 6 09-20-2003 02:33 PM
Camry rotors and brake pads speedemn Camry & Solara Lounge 6 08-10-2001 01:16 AM
