1st Problem: 2007 Camry XLE Cruise Control... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2006, 08:27 AM   #1 (permalink)
View u078356's Photo Gallery
Unhappy 1st Problem: 2007 Camry XLE Cruise Control...
After two weeks of enjoying my 2007 Camry XLE, I am now "enjoying" the opportunity to drive a 2005 model...
Friday, on our first trip out on the highway, I noticed that the cruise control wouldn't come on. Nothing lit up on the dashboard when I pressed the on/off button and the speed wouldn't lock when I attempted to engage.
I took the car into the dealership on Saturday. Waited about two hours before having to leave. When last I looked, the technician had taken the lower dash apart and had a manual open and appeared to be trying to trace down the wires. Fortunately, the dealership has a loaner program, so I do have a car.
Unfortunately, by the time the shop closed on Saturday, they had not resolved the problem. The service manager told me they will have to contact Toyota Service Support for assistance. I hope Toyota Tech. Support is better than some of the companies I have to deal with...
Part of the joys of owning a brand new model year...
Any ideas as to what the problem might be? It doesn't appear to be as simple as loose wires...
David
u078356 is offline   Reply With Quote
Old 04-17-2006, 10:00 AM   #2 (permalink)
View AESANTIAGO's Photo Gallery
I cant give you any advise but I wanted to tell you that I'm sorry that you have to go through with that cause I just went trough a transmission issue with my 07' XLE and I know exactly what you are experiencing. My dealer did not have a loaner program but they do work with enterprise so they put my in a dodge magnum for almost 3 weeks.
Good Luck and I hope it works out
2007 Toyota Camry XLE V6 , Aloe Green Metallic
AESANTIAGO is offline   Reply With Quote
Old 04-17-2006, 10:54 AM   #3 (permalink)
View prophase's Photo Gallery
Man, what is going on with these new 07's? I am holding off for now as I am reading to many negative posts about this new model. I was just about to pick on up this weekend.
Hmmm, better safe than sorry, a few months won't hurt waiting.
prophase is offline   Reply With Quote
Old 04-17-2006, 11:03 AM   #4 (permalink)
Before everyone gets down on the new Camry...
The cruise was not functioning but everything else was doing fine. I figure I paid for all the features to work, so I wanted to get this fixed sooner than later.
I believe one of the issues that we will suffer from as new model owners will simply be the lack of repair experience in the shops. These guys are seeing the guts of the car for the first time. This is the first time they get to find out how all the switches and gadgets work with the "brains" of the computer.
I have a feeling what the answer will end up being is that the brain is defective. The switch was checked and worked, the wiring appeared to be okay. But the brain controls all the interactions with the engine when running the car.
I will say that the 2005 LE I am now driving is not in the same class as the 2007 XLE!
David
Old 04-17-2006, 11:37 AM   #5 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
maybe you don't have cruise control.
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 04-17-2006, 11:58 AM   #6 (permalink)
Not right now I don't...
But I figured that lever thingee on the right side of the steering column is for more than just exotic appearances...
Old 04-17-2006, 12:27 PM   #7 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
^lol
http://www.xclusive.bz
Old 04-17-2006, 10:12 PM   #8 (permalink)
View grumbles's Photo Gallery
Almost 2k miles on my 07 SE and the cruise control works fine.
grumbles is offline   Reply With Quote
Old 04-18-2006, 12:44 AM   #9 (permalink)
View izulow's Photo Gallery
It seems that the SE's are not having any problems.Everything keeps working just right on mine and getting better MPG with every tank of gas.
izulow is offline   Reply With Quote
Old 04-18-2006, 08:08 PM   #10 (permalink)
Umm, yeah.
02AspenGreen's Avatar
View 02AspenGreen's Photo Gallery
Is this a XLE V6 you speak of?
At any moment. Toyota could be planning. To strike them. At anytime. TOYOTA. MOVING FORWARD>>
02AspenGreen is offline   Reply With Quote
Old 04-18-2006, 08:19 PM   #11 (permalink)
View msm20032003's Photo Gallery
Interesting. It's odd that the new Camry seems to be having more problems than other Toyotas. Still better than GM. This off topic....but I just bought a used 2003 Silverado ....wanted a Tundra but too expensive....and the day after I bought it the Check Engine light came on. Apparantly the gas cap was bad. Then all the lights on the radio quit. One good thing is that I bought it from a Toyota salesman that didn't know that GM's cruise control was on the Turn signal arm and I saved a couple hundred dollars....back to the point I'd rather have a Toyota than another brand.
msm20032003 is offline   Reply With Quote
Old 04-19-2006, 08:18 AM   #12 (permalink)
1st Problem: RESOLUTION!
Folks, I picked up my 2007 Camry XLE last night from the dealership. I can confirm that the XLE does come with Cruise Control and not just an extra lever on the right side of the steering column...
According to the service manager, the problem was a defective spiral wire (AKA, "clock spring") in the steering column. The cruise control portion of this assembly was not functioning.
They replaced the "Combination meter assembly R&R" and the "cable sub-assy, spir," put it all back together and everything now appears to work.
As is usually the case, the service manager told me that this was the first time he had ever had to replace a clock spring, regardless of the model...
I am hoping this is the only problem my car will have for a while...
David
Old 04-19-2006, 02:46 PM   #13 (permalink)
Camry Under Construction
05Cam-Weasel's Avatar
View 05Cam-Weasel's Photo Gallery
glad everything is working fine
Weasel(n.)- A naive user, one who deliberately or accidentally does things that are stupid or ill-advised.
05Cam-Weasel is offline   Reply With Quote
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 11:55 PM
wierd 92 camry XLE starting problem derlinn 3rd & 4th Generation (1992–1996 & 1997–2001) 1 05-14-2005 05:34 PM
camry 92 xle sunroof problem j1999t 3rd & 4th Generation (1992–1996 & 1997–2001) 1 04-10-2005 10:02 PM
99 Camry XLE DRL and HID kit problem szu604 Camry & Solara Lounge 13 10-07-2004 12:26 PM
Cruise control problem burchard Camry & Solara Lounge 7 08-17-2004 09:58 PM
