Pics of Gen 5.5 Fog Lights Please! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2006, 06:34 PM   #1 (permalink)
Gameroom cash: $254930
View LE05's Photo Gallery
Gen5 Pics of Gen 5.5 Fog Lights Please!
hey all, like the title says, i'm looking for close up pics of the gen 5.5 foglights. I'm going to be cutting the holes out of my bumper and installing OEM style fogs on my LE in a few weeks... so i'd like to know how much to cut and file the bumper to make it look stock.
LE05 is online now   Reply With Quote
Old 04-18-2006, 07:18 PM   #2 (permalink)
Gen 5 SE Camry
View Dapuzzlar's Photo Gallery
do a search and im sure you'll find what you're looking for
Dapuzzlar is offline   Reply With Quote
Old 04-18-2006, 10:00 PM   #3 (permalink)
clearly, i wouldn't have asked if i found what i was looking for. anyone else actually have something to add?
i'm looking for close up pictures of stock OEM foglights on gen 5.5's. particularly interested in the cutouts on the bumper (ie. how flush are the foglights to the bumper, angle/sharpness of the edge, etc). Since my bumper is molded into one piece, there is a slight curving to the edges of the fog "holes".
TIA
Old 04-18-2006, 10:10 PM   #4 (permalink)
Hawkeye-SE's Avatar
View Hawkeye-SE's Photo Gallery
It's as close up as I have.
Hawkeye-SE is offline   Reply With Quote
Old 04-18-2006, 11:09 PM   #5 (permalink)
View TRDGen5.5camry's Photo Gallery
you have the lip kit i didn't know that
TRDGen5.5camry is offline   Reply With Quote
Old 04-18-2006, 11:15 PM   #6 (permalink)
thanks Hawkeye-SE! that helps... seems like i'm gonna have to do a quite a bit of cutting and filing
Old 04-18-2006, 11:28 PM   #7 (permalink)
Hawkeye-SE's Avatar
The corners are going to be shitty for sure. They are not straight cuts and kind of lip in to finish the edge around the lamps themselves. Good luck.
Old 04-18-2006, 11:34 PM   #8 (permalink)
Camry Under Construction
05Cam-Weasel's Avatar
View 05Cam-Weasel's Photo Gallery
yea you are going to have your work cut out for you
Weasel(n.)- A naive user, one who deliberately or accidentally does things that are stupid or ill-advised.
05Cam-Weasel is offline   Reply With Quote
Old 04-18-2006, 11:36 PM   #9 (permalink)
Hawkeye-SE's Avatar
HA! No pun intended I am sure.
pgmomni - I like my car just fine. Reliable, practical. Not very exciting, but that is not the point. Good luck on your bid.
Old 04-19-2006, 12:24 AM   #10 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
View terrynham's Photo Gallery
this is the best pic of my one i could get for you
i had to crop if down from a 2288x1712 photo i had
~ Terry
terrynham is offline   Reply With Quote
Old 04-19-2006, 05:07 AM   #11 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $529307
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Basically, cut around the outside lines where the grooves ends. You might want to glue on some stopper liners around the edges so that there wouldn't be any leaks and loose fit. Good luck as well, it's pretty hard to cut into the bumper, you're better off getting the SE or XLE Front Bumper.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 Neochromes - More on the way
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 04-19-2006, 09:18 AM   #12 (permalink)
terrynham: even better, thanks!
xpeed: this is just temporary until I can afford to get an SE bumper and have the time to get it painted. I have a dremel with fiberglassed reinforced discs so it should make short work of the material. Once I actually get the bumper off, i'll see how it looks in the back... I'm thinking standoffs drilled into where the stock mounting points would normally be should help in keeping the foglights flush and tight.
Old 04-19-2006, 10:21 PM   #13 (permalink)
Gameroom cash: $201860
View CamrySExxx's Photo Gallery
are all the fogs on the gen5 - 5.5 the same? i think mine look a little different
CamrySExxx is offline   Reply With Quote
Old 04-19-2006, 10:32 PM   #14 (permalink)
Hawkeye-SE's Avatar
No. Gen 5 and 5.5 are different.
Lack of power - gen 4.5 v. gen 3 skewe 3rd & 4th Generation (1992–1996 & 1997–2001) 43 07-11-2007 12:40 PM
Gen 5, Fog Light wirering mod SCARY! (pics no 56kers) majorgercko1 5th & 6th Generation (2002-2006 & 2007-2011) 8 02-01-2006 06:24 AM
Gen 4/Gen 4.5 Fog Lights aleks77 3rd & 4th Generation (1992–1996 & 1997–2001) 6 03-03-2005 03:07 AM
RX300 Fog Lights hambone575 General Lexus Discussion 0 02-17-2005 02:05 AM
