Gen 5 headlight upgrade suggestions - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2006, 12:23 AM   #31 (permalink)
Alloy's Avatar
View Alloy's Photo Gallery
I have a kinda silly question, should my lighting output has the LHD beam/pattern? Coz I don't think mine has it. Would that due to the fact that I am using the stock housing, or I and everyone eles probably have the LHD pattern, just I didn't notice it.
:creature:07 Magnetic Grey Metallic SE
Alloy is offline   Reply With Quote
Old 04-23-2006, 12:27 AM   #32 (permalink)
day dreamer
View OrangeJuice's Photo Gallery
I think everyone else has a straight cut off. my old OEM housings looked exactly like yours before I took them off.
OrangeJuice is offline   Reply With Quote
Old 04-23-2006, 12:54 AM   #33 (permalink)
Hawkeye-SE's Avatar
View Hawkeye-SE's Photo Gallery
Well... its not really a straight cut off (that is for Fog and auxillarly lights only). The problem is that the cutoff of the stock reflectors is so blurry that it is indefinite.
Hawkeye-SE is offline   Reply With Quote
Old 04-23-2006, 02:30 AM   #34 (permalink)
View fredster34's Photo Gallery
Gen5 Re: 9005 conversion
Originally Posted by DOHCammer
I'm using 9005 GE Nighthawks in my Gen 5 low beams and high beams and find them to be the best bulbs I've used. The low beams put a lot more light on the road although the distance is limited by the headlamp design. The high beams definitely reach out further with more spread. The 9005 low beam retrofit is easy to do and even with a stock replacement bulb will show an improvement over the 9006 bulbs. I'd stay away from the blue tinted bulbs, even SilverStars are not as bright as the Ge's.
so when u put 9005's in the low-beams, do u need to re-aim the headlights? and how and/or wut tool did you use to remove the plastic tabs on the 9005's? holler!
fredster34 is offline   Reply With Quote
Old 04-23-2006, 02:43 AM   #35 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
http://toyotanation.com/forum/t6831.html
^ Read under "more light"
"Skoolin' the unlearned!"
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
gen 3.5 - ring inside headlight housing frighte 3rd & 4th Generation (1992–1996 & 1997–2001) 0 12-14-2005 10:15 PM
Gen 5 headlight ballasts power problem majorgercko1 5th & 6th Generation (2002-2006 & 2007-2011) 5 12-05-2005 11:19 AM
