So, the May issue of Road & Track, page 81, lists the following specs:
The performance numbers are out for 2007 Camry SE V6, 6AT.
1/4 mile: 14.5@99.9 mph (5/06 R&T test 61F, 350ft)
There is another vehicle test in the same issue, Passat 3.6, 6AT
1/4 mile: 14.5@100.2 mph (5/06 R&T test 94F, 350ft)
They are faster than '04 TL with 6MT
1/4 mile: 14.8@96.6 mph (4/04 R&T test 88F, 150ft)
and '04 Accord coupe EX-V6.
1/4 mile: 14.8@97.2 mph (3/04 R&T test)
The surprising thing about it is it is Camry was actually quietest at constant 70mph.
TL is at 70dBA, EX-V6 coupe at 71dBA, Passat is at 72dBA, while the Camry was 68dBA.
AND comparing handling of the SE to a coupe:
The '07 Camry SE V6 with 215/55-17 Toyo Proxes J33 did 0.83g and 63.6mph
The '04 EX-V6 Coupe with 215/50-17 Michelin Pilot HX MXM4 M+S did 0.81g and 63.9mph.
__________________________________________________ ___________________________________
And if you really want to have fun/be dangerous I have personally confirmed that the Lexus procedure to disable the VSC works on the Camry, and it disables the traction control. Supposedly, according to a post on Edmunds (Inside Line) forums, some kid is claiming a 0-60 time of 5.7 with the traction control disabled. He also says he has a flowmaster exhaust on it
