Is my '05 trying to tell me something? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2006, 06:24 PM   #1 (permalink)
View mdw_houston's Photo Gallery
Hey Guys... great forum here.
Here's my problem. Every time I get out and lock my '05 Camry I get 5 quick horn beeps about 10 minutes later. At first I thought I was pushing the 'panic button' while the remote was in my pants, but it happens all the time. I have looked through the owners manual, and searched the message boards. I am stumped!
Anyone have any ideas?
Thanks in advance.
Mike in Houston
mdw_houston is offline   Reply With Quote
Old 04-21-2006, 08:17 PM   #2 (permalink)
Gameroom cash: $255930
View LE05's Photo Gallery
that's odd... doesn't happen on my '05. do you have a factory alarm system?
LE05 is offline   Reply With Quote
Old 04-21-2006, 09:39 PM   #3 (permalink)
Alloy's Avatar
View Alloy's Photo Gallery
exactly, my 04 doesn't have the beep sound, but I guess mine doesn't come with the alarm.
:creature:07 Magnetic Grey Metallic SE
Alloy is offline   Reply With Quote
Old 04-21-2006, 09:44 PM   #4 (permalink)
Camry Under Construction
05Cam-Weasel's Avatar
View 05Cam-Weasel's Photo Gallery
you've got me all i can think of is if you have a aftermarket alarm but it sounds like you have the stock one that comes with the car
Weasel(n.)- A naive user, one who deliberately or accidentally does things that are stupid or ill-advised.
05Cam-Weasel is offline   Reply With Quote
Old 04-21-2006, 10:40 PM   #5 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
Thanks in advance.
Mike in Houston
Some alarms will give off a sound if the battery is low. I'm not sure if this is the case with a factory alarm. When you are driving the battery is charging, then once you park your car, the voltage starts to drop on a weak battery. But if you have a GEN5, not likely a battery problem... hmmm. this is a puzzling one. but check the battery just in case.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 04-23-2006, 03:20 AM   #6 (permalink)
View pcgeek's Photo Gallery
Thanks in advance.
Mike in Houston
This is usually an indication that there is a problem with the alarm system circuit. It could be as simple as there is a door ajar, one of the door switches not working, or one of the door locks isn't working etc.... Have the alarm system checked. Alarm System fault.
pcgeek
pcgeek is offline   Reply With Quote
Old 04-24-2006, 05:59 AM   #7 (permalink)
Big Wrench
View Mikey21's Photo Gallery
I have an 04 that got into an accident on the passenger right front. After the accident I have the same thing that you described. But it only happens when I park on my driveway facing forward (my driveway is inclined about 30 degrees). It never happens any other time, so when I park in my drive way I now reverse in with my nose down. I figure it's related to the alarm system tilt sensor or such (I have the OEM Toyota Alarm).
Hope this helps,
Mike
Old School Wrench/ New School Ride
My Camry Pic's
Mikey21 is offline   Reply With Quote
'05 Camry Aluminum wheels on '05 Corolla Williams Archived Corolla threads 2 09-13-2005 07:18 AM
05 Tacoma Purchase Questions jctingler 2nd Generation (2005+) 6 05-10-2005 05:32 PM
05 Camry different than 02-04? p@nda 5th & 6th Generation (2002-2006 & 2007-2011) 16 02-28-2005 02:39 PM
Just bought an '05 Tundra willjohnson33 1st Generation (2000–2006) 3 10-14-2004 03:23 PM
05 vibe vs. 05 matrix? northcoast 1st Generation (2003-2008) 5 03-29-2004 08:42 PM
