CAMRY 07 Oil Filter location? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2006, 03:14 AM   #1 (permalink)
View Calvin327's Photo Gallery
Hey guys/gals, anyone know where the Oil filter is on the 2007 Camry V6? Also where is the transmission dipstick? Thanks in advance.
Calvin327 is offline   Reply With Quote
Old 04-22-2006, 09:36 AM   #2 (permalink)
Toyota Parts since 1981
Gameroom cash: $146955
View DOHCammer's Photo Gallery
Your oil filter is a cartridge type, not a normal cannister. You must go beneath the car to see it hanging down right by the oil pan. You have to take the housing off to get to the cartridge. As for the trans, I believe you have one of the new sealed transmissions which means no dipstick. A quick look in your owners manual will fill you in on both these concerns.
07 Camry SE V6
TRD Dual Exhaust & Air Filter
05 Highlander V6 AWD
170K miles young
DOHCammer is offline   Reply With Quote
Old 04-22-2006, 09:53 PM   #3 (permalink)
Thanks, I'll look into it.
Old 04-22-2006, 10:08 PM   #4 (permalink)
View articledon's Photo Gallery
Gen 6 doesnt sound very DIY friendly
2003 LE 20% tint all around
Future plans: 18" rims, foglights,new stereo system
articledon is offline   Reply With Quote
Old 04-22-2006, 10:33 PM   #5 (permalink)
View so40's Photo Gallery
Oil Filter 07 V6
Well, I can't find anything in the Owners Manual about changing the oil filter. There are several pages about the type of oil and checking the oil but I do not see anything about changing the oil or filter. However, it is a cannister type system with a cartridge filter in it.
On the bottom of the canister is a round drain plug that you take off with the end of a 3/8 drive ratchet. The new filter kit comes with a plastic fitting that then pushes up into the cannister (or housing) and you attach a hose to it (before pushing it in) to drain the oil in the cannister. Then you unscrew the cannister or housing (whatever you want to call it) with a filter wrench. I got lucky and the filter wrench I bought for my son's 05 V6 Honda Accord happens to fit this housing. It is one that fits on a 3/8 ratchet. I don't know the size but it fits the stock factory Honda 2005 V6 filter.
The Toyota filter kits come with 2 new "O" rings, one for the drain plug and one for the cannister and the plastic "pipe" for draining the cannister. The Toyota part number is 04152-31090 for the filter.
Also, the owners manual doesn't show anything about checking the transmission fluid either. I haven't had time to look into that yet.
Mike
so40 is offline   Reply With Quote
Old 05-09-2006, 10:17 PM   #6 (permalink)
Sheep in Wolfs Clothing
View 94camryxle's Photo Gallery
If anyone can post some pictures with oil and oil filter replacement procedures, that would be greatly appreciated.
94camryxle is offline   Reply With Quote
Old 05-10-2006, 05:42 PM   #7 (permalink)
Camry97
View ichlove's Photo Gallery
Sounds like pain to change & probrably cost alot more.
ichlove is offline   Reply With Quote
Old 05-10-2006, 05:57 PM   #8 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $263242
View csaxon's Photo Gallery
http://members.cox.net/n0v8or/avalon_oil_change.pdf
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 05-10-2006, 06:03 PM   #9 (permalink)
2007 RED Camry XLE Owner
Old Dood's Avatar
View Old Dood's Photo Gallery
the Dealership where I bought my Camry has a $17.00 deal on oil changes. I will let them hassel with it...
"We can't solve problems by using the same kind of thinking we used when we created them." Albert Einstein
Old Dood is offline   Reply With Quote
Old 05-10-2006, 06:23 PM   #10 (permalink)
Thanks!
Originally Posted by csaxon
Thanks for the great post!
Old 05-10-2006, 08:06 PM   #11 (permalink)
X Avalon
View hsakuragi's Photo Gallery
make sure they put 6.4 qts of oil..NOT 5
hsakuragi is offline   Reply With Quote
Old 05-10-2006, 08:29 PM   #12 (permalink)
View JAG66's Photo Gallery
My 66 Corvette Sting Ray has the original cannister filter and it's very messy. Also, be sure to remove the old O ring and position the new O ring correctly or you could have a bad day. Definitly not DIY friendly. I don't understand why Toyota would do this.
JAG66 is offline   Reply With Quote
Old 05-10-2006, 09:53 PM   #13 (permalink)
View Novice_cardude's Photo Gallery
Yeah man, they were doing good. All you had to do before was get around the exhaust manifold from the top ... now a canister? Those are for Volkswagens and Audis ... gah.
Way to go Toyota...
Novice_cardude is offline   Reply With Quote
Old 05-10-2006, 10:23 PM   #14 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
I think more and more car makers are doing this. Mazda started it a few years ago, and I believe Honda did too. The reason is to save money and make it eaiser to recycle.
drunken_panda is offline   Reply With Quote
Personal Camry Websites - POST HERE Silver Streak Camry & Solara Lounge 193 08-03-2011 12:56 PM
2007 Camry Oil Filter Location? kytaco 5th & 6th Generation (2002-2006 & 2007-2011) 3 01-27-2006 08:56 PM
does a f2 oil filter fit in i4 camry pkchi Camry & Solara Lounge 11 07-19-2005 02:30 PM
Oil Filter FrankXT86 Camry & Solara Lounge 4 11-10-2004 09:31 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 05:39 AM
