2006 Camry alternator whine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2006, 04:30 PM   #1 (permalink)
View Nicu's Photo Gallery
Unhappy 2006 Camry alternator whine
The alternator in my 2006 Camry makes a whining noise when braking/decelerating. From inside the car the whining noise can only be heard on smooth pavement, with the radio off and with the ventilation fan off. I've read that Camry's and Sienna's are known for noisy alternators. Should I try to have the alternator replaced under warranty or is this 'normal'?
N
Nicu is offline   Reply With Quote
Old 04-24-2006, 06:06 PM   #2 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
alternator whine by definition will be heard from your speakers, so if your radio is off, obviously this is not the case. you might be hearing something else.
johnnyzee is offline   Reply With Quote
Old 04-24-2006, 06:50 PM   #3 (permalink)
I used a funnel to figure out what part of the engine area the whining noise was coming from, it's definitely from the alternator.
N
Old 04-24-2006, 07:20 PM   #4 (permalink)
View Ken4's Photo Gallery
More likely timing chain whine if you ask me.
Ken4 is offline   Reply With Quote
Old 04-24-2006, 11:23 PM   #5 (permalink)
If I turn the radio and the headlights on the whininig gets louder - form what I read that means that it's the alternator...
N
Old 04-25-2006, 08:20 AM   #6 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $400224
View BlackCamSe's Photo Gallery
not necessary, it could be something ells. When you turn no you radio and headlights or high beams it puts more of a strain on the engine because the alternator has to work herder...If the engine works harder then it could be making what ever is making the noise more noticeable.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 04-25-2006, 09:36 AM   #7 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
errr how many miles?
timing belt could be worn out...or does the 06 cam use a chain?
Also if the whine is heard through your cabin speakers you have some grounding issues with your stereo and general electrical system that should be fixed.
nodrogkam is offline   Reply With Quote
Old 04-25-2006, 10:03 AM   #8 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
the 2AZ-FE uses a chain...the 1MZ-FE and 3MZ-FE use a belt.
Old 04-25-2006, 11:07 AM   #9 (permalink)
1200 miles, 4 cyl Camry. No whine through the speakers...
N
Oil Filter Part Number - 2006 4Cyl Camry? zzCamryzz 5th & 6th Generation (2002-2006 & 2007-2011) 7 03-30-2006 11:45 AM
2006 manual shift camry wanted.... MaitreBien 5th & 6th Generation (2002-2006 & 2007-2011) 1 03-17-2006 06:47 PM
2006 Special Edition Camry... Archosman 5th & 6th Generation (2002-2006 & 2007-2011) 5 03-17-2006 04:40 PM
2006 Camry: Beep and then radio shuts off kaikow 5th & 6th Generation (2002-2006 & 2007-2011) 12 02-11-2006 04:37 PM
Will 2006 Scion CD/SAT/MP3 head unit fit in Gen 4 Camry? leasure23 3rd & 4th Generation (1992–1996 & 1997–2001) 1 11-14-2005 05:04 PM
