'07 Camry - Smart Key (push-button start) Question
After some initial fightiing with the Smart Key / Push-Button Start (SK/PBS) system, I think I've finally mastered it (for the most part). One thing that irritates me is that I can't transition from the on-and-running mode to the accessory mode, without cycling through full power off mode. Why is this an issue? Let me describe a typical scenario.
I'm happily motoring along in my shiny new '07 V6 XLE, safely using the Bluetooth hands-free system to participate on a concall, when the need to write something down or look something up arises. I pull over and park, and accomplish the task. However, this extends to more than five minutes, so I'd like to turn the car off and finish the call, while saving expensive fuel. If I had a normal key, I'd just switch from "on" to "accessory" mode, and keep yapping. However, with the SK/PBS system, I can't do this. If you shut the car off, you lose Bluetooth connectivity (no matter how fast you cycle the button), and the call is interrupted. The manual doesn't address this, nor have I been able to figure out any combination of brake pedal, short- or long-button push, etc. to make this happen.
Any ideas?
Marc
