Camry 07 SE Intall Amplifier help.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2006, 12:52 PM   #1 (permalink)
View dutaduta's Photo Gallery
Unhappy Camry 07 SE Intall Amplifier help..
Could any one help me, where can I run the power cable through the firewall for my Camry 07, I can not see any hole from the firewall..
thanks
Du
dutaduta is offline   Reply With Quote
Old 05-10-2006, 03:06 PM   #2 (permalink)
Spectraman
View youngkow's Photo Gallery
You'll probably just have to drill one, and also get a grommet for that hole. I have never seen any cars that just had exposed holes. They all had some sort of plug.
youngkow is offline   Reply With Quote
Old 05-10-2006, 03:10 PM   #3 (permalink)
View netherland24's Photo Gallery
ur car needs one to bedrilled. sorry get a step bit. what size wiring u gona run through it? also get boots so u get dont water leak...
check partsexpress.com for firewall boot.
01 Camry SQ project
netherland24 is offline   Reply With Quote
Old 05-10-2006, 05:17 PM   #4 (permalink)
I'm using 8 gauge, drilling???does it effect on the warranty??thanks for prompt response..
if any one has the pics for the hole drill please, share with me.
thanks
Du
Old 05-10-2006, 09:09 PM   #5 (permalink)
View adrand's Photo Gallery
Just out of curiosity, did you replace the head unit as well? If not what are you using for the audio input for the amp? Also are you replacing any of the stock speakers? I recently contacted Crutchfield and they are telling me that as of now no aftermarket speakers will fit in the '07 camry stock holes. Sounds a little strange to me. The rear two look like pretty standard 6x9's.
adrand is offline   Reply With Quote
Old 05-11-2006, 08:38 AM   #6 (permalink)
View izulow's Photo Gallery
All the speakers are 6x9. When replacing the speakers you will have to fab up some trim plates to make them fit properly. This weekend I will be trying to see if the Solara dash kit will work since they are made off of the same frame structure for the dash. I will be able to update more on Monday.
izulow is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Can I Retrofit 2005 Camry SE Headlights to a 2002 Camry LE??? LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 20 07-31-2006 10:54 PM
Question about 07 Camry SE Edition ayeaye 5th & 6th Generation (2002-2006 & 2007-2011) 6 04-28-2006 04:33 PM
2007 Camry SE V6 Performance/Traction Control wireless 5th & 6th Generation (2002-2006 & 2007-2011) 6 04-22-2006 01:37 PM
Camry SE: Gen3 vs. Gen5? chasman 3rd & 4th Generation (1992–1996 & 1997–2001) 12 03-30-2006 12:48 AM
