help...chipped paint from rock on my 07 camry se - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2006, 07:04 PM   #1 (permalink)
View obeythelaw's Photo Gallery
I am in need of advice. My 1 month old metallic blue 07 Camry SE V6 has a chipped paint on the front hood. Its not one of those "superficial" chips either. It's a about a quarter inch wide and I can see some type of plastic clear material underneath the chip. My concern is that this can lead to rust. Should I bring it to Toyota and see if they can work on that for me. Will they charge me a lot? Will they be able to touch up just that spot?
obeythelaw is offline   Reply With Quote
Old 05-24-2006, 09:45 PM   #2 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
welcome to the club mate. you can expect more to come too. that sounds like down to the base primer. you can do it yourself, search here and also the web on how to fix paint chips... cheaper to do it yourself. step by step process, clean it , prime it, paint it, etc.... you can do it grasshopper. i have done around 10 chips on my car thus far too. good luck
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
Old 05-25-2006, 08:22 AM   #3 (permalink)
Posting via Handheld
wireless's Avatar
View wireless's Photo Gallery
I have the same thing. Once I get the chips (more than one of them from that f-in dump truck), I am getting a clear bra.
This is where you insert your signature
wireless is offline   Reply With Quote
Old 05-25-2006, 11:11 AM   #4 (permalink)
View knotquiteawake's Photo Gallery
see through? that's hot.
knotquiteawake is offline   Reply With Quote
Old 05-25-2006, 02:52 PM   #5 (permalink)
Sheep in Wolfs Clothing
View 94camryxle's Photo Gallery
Here's an E-Bay listing:
http://cgi.ebay.com/ebaymotors/TOYOT...spagenameZWD1V
94camryxle is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
INFO: 1996 Toyota Camry Specifications Ratko 3rd & 4th Generation (1992–1996 & 1997–2001) 22 08-08-2009 05:09 PM
Can I Retrofit 2005 Camry SE Headlights to a 2002 Camry LE??? LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 20 07-31-2006 10:54 PM
05 Camry SE Owners.... Camdaddy 5th & 6th Generation (2002-2006 & 2007-2011) 6 11-20-2004 12:11 AM
