check your 07 camry for defective gas pump
Hi everyone, I would like to inform you about a problem that I've encountered and could possibly happen to you. Basically, after driving about 1k miles, I found that my new camry was making air escaping's sound near the rear tire area. I did a little troubleshooting and found that only when the car is on does the noise exist. I thought that it was just normal engine noise, but after many days of hearing this noise, I decided to take it back to the dealer. The dealer also believe that it's a normal engine noise, but I didn't believe that after 1k miles the engine would make that much noise. Although they didn't want to check it out, I asked them to check it out anyways. It turns out the gas pump was defective and need to be replace. The part takes about a month and a half to be delivered and I've been waiting impatiently, but at the same time I would rather be safe to drive so I had no choice except to wait. I recommend you check this out as my dealer said that they are getting more of these gas pump issue. Hope you don't have this issue.
