15,000 miles or 18 months
Replace engine oil and oil filter 1
Rotate tires
Clean cabin air filter
Visually inspect brake linings/drums and brake pads/discs Inspect the following:
Ball joints and dust covers
Brake lines and hoses
Drive shaft boots
Engine coolant 3
Exhaust pipes and mountings
Steering gear box
Steering linkage and boots
Note: Driving in heavy traffic, on dirt roads or in urban, dusty or desert areas may shorten the life of the cabin air filter. Replacement may be needed if you notice reduced air flow from the air conditioner and heater or if the windows fog easily when you use the "fresh" mode. Consult your dealer if any of these conditions occur.
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
Tighten nuts and bolts on chassis
Driving in Desert or On Dirt Roads
Inspect engine air filter
Applicable Footnotes:1) Reset the oil replacement reminder (“MAINT REQD”) light after replacing engine oil, if vehicle is equipped with this light.
3) See Maintenance Definitions (Engine Coolant) for details.
Rotate tires
Drive shaft boots
Engine coolant 3
Steering gear box
