Just purchased a new '07 LE (first post) with break-in procedures - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2006, 11:07 AM   #1 (permalink)
View Forced Induxion's Photo Gallery
Gen6 Just purchased a new '07 LE (first post) with break-in procedures
Last night the fiance and I went and purchased a new '07 Camry LE 2.4L I4 in super white. We're picking it up at the dealership on Monday (straight off the truck). Anyways, I didn't want to just sit here and post a "hey look at me" post with our new ride since I'm sure there are tons of them.
So in order to be helpful for others out there here are some break-in procedure instructions that I used for my Audi and worked great. I'm sure someone else posted some break-in instructions but I really like this one. I trust it and I trust the author and plan on using it for my Camry.
*SORRY ITS LONG*
The Practice.
>For the first 100 miles, only take short trips of <15 minutes. Do not rev above about 3500 rpm. Use full throttle in short (2-3 second) bursts at low rpms (say 2500) - 5th gear on the freeway is ideal for this. Do not do more than one full-throttle burst in the same 2-minute period. Avoid driving for more than 2-3 minutes at the same rpm - if you are on the freeway, vary your speed and alternate between 5th and 4th gears.
>From 100-500 miles, increase the peak RPM you reach by 200 rpm each time you drive the car (but don't go higher than redline). Do not rev to your new peak under heavy throttle; instead, let the engine drift up to the rpm under light load. For instance, pulling away from a stoplight, leave the engine in first and accelerate lightly until you reach the desired RPM, then shift. Continue the full-throttle-burst procedure. Do not rev the engine high under full throttle, and do not do either the peak-revving or the full-throttle procedure more often than once a minute. Avoid driving for more than 5 minutes at any one rpm - again, alternating between two adjacent gears and varying your speed will work.
You will notice that each time you reach a new peak rpm, the engine will be quite loud at that rpm, but after a few runs up it will quiet down. This is a sign that the break-in is proceeding well. You will want to have revved the engine to redline a few times by the time you reach 500 miles. At that point I recommend you change the oil, as most of the metal wear and contaminants from break-in are released in the first 500 miles.
>From 500-3000 miles (the extended break-in) you can operate your engine fairly normally. Most of the work is done. You should still run the engine at higher RPMs on a regular basis (assuming you don't in the normal course of driving ;-) ) and you should avoid prolonged high-speed/high-stress operation, like racing or cruising at 110 mph. I personally change the oil after 1500 miles since it will be dirtier at that point that it would be after 3000 miles of post-break-in operation, but it isn't critical. Be sure to change it at 3000 miles, however. Although there is some difference of opinion on what KIND of oil to use during break-in, the general consensus is to use normal (non-synthetic) oil of the recommended weight (5- or 10-30).
>From 3000 miles onward, your engine is considered broken in. It will probably continue to "loosen up" a bit over the next 3000-6000 miles, so look for a small increase in gas mileage. Other than that, your engine is now be ready for a long and productive life. Enjoy!
***** BEGIN TECHNICAL SECTION *****
The Theory.
The primary goals of engine break-in are: 1) achieving a good seal between the piston rings and cylinder walls, and 2) allowing the engine to operate correctly throughout its RPM range. The major enemy during the break-in period is localized heat buildup, mainly in bearing surfaces (most notably the crankshaft bearings).
Initial state:
When the engine is machined at the factory, many wearing surfaces (places where parts rub against each other - cylinder walls, bearings, etc) are purposely machined more roughly than they could be. The reason for this is that it allows the engine to complete the machining/polishing as it operates, thus allowing for the individual variations inherent in any manufacturing process. This wearing process, when complete, produces parts which will fit together with very tight tolerances. However, the process also involves a great deal of friction, which in turn means a great deal of heat. As metal parts heat, they expand slightly. If the expansion goes beyond a certain point, the parts will tend to bind with and/or score each other. This must be avoided.
[To put this in plain english, the parts which rub against each other are left a bit rough, and as the engine runs the parts will scrape against each other until they wear down a bit and have a proper fit. While they're still in the process of scraping, they can get very hot; if they get too hot, they will damage each other in a permanent way.]
Since this sort of heat buildup is very localized, it will not show up on the engine temperature gauge. Therefore, it is important to operate the engine in such a way that the heat buildup will not reach a dangerous level. More on this later.
Stress and Variation:
Although the engine parts are metal and, as a rule, quite rigid, they are still subject to slight deformation when stress is applied. The largest stress in a piston engine is that produced by reciprocating parts. The forces involved increase as the square of the RPM. Any deformation will necessarily involve a change in some tolerances inside the engine. Thus, in order for the engine to operate properly over a range of RPMs, it is important that it be exercised over this range during the break-in process so that the wearing parts will experience the range of tolerances they will be subjected to during normal (post-break-in) operation. Further, for the wearing surfaces of reciprocating parts (most notably the piston ring/ cylinder wall interface) operation at a single RPM for an extended period of time will cause the machining process to progress significantly further within the confines of the part's range of travel without progressing at the point just outside that range, thus building up a small ridge of metal just above the point of maximum excursion.
[In order for your engine to run well from 1000 to redline, you need to operate it at all those rpms while it is breaking in. If you don't, the parts won't be used to working at the rpms you neglected, and they won't work as well at those speeds]
Piston Ring Sealing:
The seal between the piston ring and the cylinder wall is crucial to getting good economy and performance from the engine. A bad seal will allow more blow-by, reducing the amount of power the engine can produce with each power stroke and thus reducing both its horsepower and fuel economy, as well as allowing combustion gasses to get into the crankcase and contaminate the oil AND allowing oil to get into the combustion chamber and be burned, producing the characteristic blue-smoke-from-the-tailpipe syndrome (note that oil can also get into the combustion chamber via the valve stem guides, but that's not something we can do much about during break-in).
The key to getting a good piston ring seal is high combustion chamber pressures. Embarrasingly, I don't know why (can someone fill me in?). High combustion chamber pressure is produced under hard acceleration; also, the lower the RPM the longer that pressure is maintained during each power stroke. SO - to get a good piston ring seal, hard acceleration at low RPMs will give the best results. Since hard acceleration also produces more heat and more stress (leading to friction and still MORE heat), it should only be used in brief bursts, followed by a couple of minutes of "normal" low-stress operation to allow the heated parts to cool down.
Localized Heat Buildup:
As previously mentioned, wearing parts will produce inordinate amounts of heat as they polish each other. This produces local points of intense heat inside the engine, with temperatures far higher than the engine as a whole (which shows up on the temperature gauge) or even of the surrounding parts. The most susceptible points in an engine for this kind of heat buildup are the crankshaft bearings, which must withstand enormous stress and pressure. If the bearings are allowed to get too hot, they will expand to the point of scoring each other or (*gulp*) binding, producing a spun bearing. During the initial stages of engine break-in, there is no satisfactory way of keeping these bearings cool during even mild engine operation except to turn the engine off after every 10-15 minutes of operation and allow the bearings to cool down.
The theory I have outlined about should now be sufficient to explain the "practice" section of the break-in instructions. For the first 100 miles, keep the rpms low and the trips short to minimize the stresses and heat buildup in the bearings, and use short full-throttle bursts to seal the piston rings. From 100-500 miles, gradually increase the RPMs to allow the wearing surfaces to correctly mate, and continue using full-throttle bursts to ensure ring sealing. Use cooling periods (the 1-minute rule) to minimize the heat buildup produced by the high RPM operation and the full throttle bursts. At 500 miles, change the oil to flush out all the metal particles produced by the wearing process.
2002 Metallic Silver Audi A4 1.8T Sport/Premium Package
2004 Aspen White Volvo S60 2.5T Sport Package
2006 Alabaster Silver Metallic Honda Accord 2.4L Special Edition
2007 Super White Toyota Camry 2.4L LE
Forced Induxion is offline   Reply With Quote
Old 07-15-2006, 03:18 PM   #2 (permalink)
View Winterpeg's Photo Gallery
Canada Good Theory but it's only theory!
Good afternooon;
Not sure if I posted my break-in procerss on this board but the theory is simple, drive the car from day one the same way you will be driving it when you get rid of it! We have owned dozens of cars, from 4 to 8 cylinders(not sure what you meant by 4 stroke engines but all are 4 stroke other than my 2 stroke Lawnboy lawn mower) and I have never added any oil between changes(change every 6 months) and I redline all our cars on a regular basis.
Just drive the car and don't worry about breaking in the car, if it breaks, that's what the warranty is all about.
Relax and have a great day;
2007 Camry SE V6 2000KM and first redline was at about 150 KM mark..
Winterpeg is offline   Reply With Quote
Old 07-15-2006, 05:20 PM   #3 (permalink)
winterpeg,
The problem with not properly breaking in your car is that it will not perform as optimally as it can. I'm sure it will still run and you may never run into problems without following any type of break-in instructions...but the purpose of properly breaking in the car is to maximize its performance. I never followed any break-in instructions until my last car and I'm not sure if its because of breaking it in really well but I actually got better gas mileage than what the sticker said on the window.
I figured it couldn't hurt to try right? If anything I could only really benefit from it.
Old 07-16-2006, 12:34 PM   #4 (permalink)
Streaker
Gameroom cash: $121159
View Streaker's Photo Gallery
Thats more information than than the Canry owners manual
Streaker is offline   Reply With Quote
Old 07-16-2006, 12:41 PM   #5 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Great information! I read someinthg like this off a website once, they recommended pushing the car to seal the rings instead of driving easy.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 07-16-2006, 07:58 PM   #6 (permalink)
Sorry I just realized what I wrote there... sorry I confused stroke for cylinder. DUH all our engines are 4 stroke. Sorry I fixed that part.
Old 07-16-2006, 09:39 PM   #7 (permalink)
View sephknite's Photo Gallery
Hmm..what gear should I redline? Can I do it while the car is parked?
Ohh, I'm about to hit 500 miles on omy SE. Should I bother going to the dealership to change my oil or just any oil change is ok?
sephknite is offline   Reply With Quote
Old 07-16-2006, 09:45 PM   #8 (permalink)
Redline any gear... the purpose is not only to break in your engine but also the transmission. I definitely WOULD NOT redline while parked or when the engine is still cold.
Isn't the 1st oil change free from the dealership? call them and find out.
I should also add to my original post that bedding in the brakes should also be done if there aren't many miles on the car already.
Old 07-17-2006, 01:19 AM   #9 (permalink)
Dealer says the first 5000 mile checkup/oil change is free. Wondering if I can have them do just the oil change, or do you recommend the 500 change to be done just anywhere.
Old 07-17-2006, 07:29 AM   #10 (permalink)
Well I'm not sure about toyota but I know some dealerships like to check to make sure things are wearing correctly during break in. Usually the first check up pretty important. Also during the early stages if something is not wearing correctly its ALWAYS easier to get it fixed because its embarrassing for dealerships when their brand new cars are breaking down. Just check your service intervals in the manual. If the manual says anything earlier than 5000 miles then I would take it up with Toyota of America or whatever the head office is here. If they don't do it for free then I say just take it to the dealership anyways for the oil change at least at 1000 miles. There are lots of metal bits in your fluids during break in and I wouldn't want that to be in there too long b/c parts will wear faster.
I found many coupons off my local toyota dealers' websites for $25 oil changes. If they don't do a free one at least at 1000 miles just pay a little bit and get it done. Thats my recommendation.
Yet another '07 help me post 02whiteLE 5th & 6th Generation (2002-2006 & 2007-2011) 23 05-26-2006 10:15 AM
SE better than LE for my new car...Comments? kthan Camry & Solara Lounge 20 09-06-2005 11:46 AM
Break Noise from rear break(2000 Camry) abc_1126 3rd & 4th Generation (1992–1996 & 1997–2001) 5 10-10-2004 01:04 AM
