2002 Camry - First failure: Battery (maybe more?)
My camry died yesterday, and I discovered that it was the battery. After 3 jump-starts to get to/from work, I picked up a new battery and installed it today.
I did alot of research about the charging system, just in case it was something other than the battery at fault. (The car died on me once after a jump start at a traffic light, and again when I pulled into my parking spot, which let me to suspect something w/ the alternator) From what I've read, the output from the alternator should be ~14.5 volts when the car is started.
After I installed the battery, the car started up just fine. I measured the voltage at the battery, and it read 14.1, as expected.
Then, I went inside the car, turned on the fan, high beam, defogger, and every other accessory i could find in the car.
I went back out to measure the voltage accross the battery, and it was back down to 12.5ish volts.
After shutting down the engine and restarting, the voltage stayed at 12.5ish volts. It didn't seem like I could get the voltage back to 14.x volts?
I waited a couple hours, went back outside, started the car, and measured the voltage again: 13.x volts. I decided I was going to try driving it around the block, but chicked out when I backed up, and the car started to feel like it was going to stall. I got out and measured the battery voltage again while the car was still on: 12.x volts.
The car also studdered like it was about to die. I called the toyota dealership, and he said, "I wouldn't worry about it." He told me to drive a couple miles and it should steady out (which it did. I guess the ECU was relearning)
So my question is, is this normal??? Shouldn't the output at the battery be 14.1 volts (to charge the battery)??? How is my battery charging if the voltage is 12.x volts?
