Need a ECU Wiring GURU for Emanage Ultimate on a 2002 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2006, 03:29 AM   #1 (permalink)
Mid Life Crisis's Avatar
View Mid Life Crisis's Photo Gallery
Hey Gang,
I hope someone can shed a little light on my frustrating project...
I own a 2002 Camry LE 2.4L (2AZ-FE) that is in the process of some major modifications. Knowing that the stock ECU isn't going to cut it, I purchased the GReddy EManage Ultimate as the piggyback. My hurdles started with the fact that GReddy does not have any examples for the Camry, so after researching, I was going to use the Scion Tc ECU pinout example for a guide. I later found out that it is close, but not exactly the same. I am now trying to "start from scratch" and make sure the proper wires are chosen for the install.
I have attached the wiring diagrams, ECU examples, pinout ID, and what I think are the correct locations. I believe the only thing I still need to locate is the ground & sensor ground locations. If someone with some knowledge, or anyone else for that matter, can confirm my choices or let me know the correct locations, I would greatly appreciate it.
Thank You Very Much!
Jason
Nothing... and I mean nothing, can ever be stock!
http://www.cardomain.com/ride/2380846
Mid Life Crisis is offline   Reply With Quote
Old 07-28-2006, 03:56 AM   #2 (permalink)
View Ken4's Photo Gallery
Open up your ECU and see if the pcb is labelled.
Ken4 is offline   Reply With Quote
Old 07-28-2006, 04:03 AM   #3 (permalink)
Give me a few minutes.
Old 07-28-2006, 04:18 AM   #4 (permalink)
These are the only two numbers that I can See.
Old 07-29-2006, 07:40 AM   #5 (permalink)
Download the Gen 5 EWD and follow the color coding, it should be quite accurate.
http://rapidshare.de/files/23267350/02EWD.pdf.html
Old 07-29-2006, 06:40 PM   #6 (permalink)
Old 01-09-2011, 04:08 AM   #7 (permalink)
View tobsta's Photo Gallery
Does anybody have a copy of this PDF that they could re-host and PM me please? I desperately need it and am unable to find it anywhere.
Cheers
Toby
tobsta is offline   Reply With Quote
Again: which cd/tape players fit 2002 Camry undrcroft Audio, Video, and Security - Tech 4 07-28-2007 02:18 PM
2002 V6 Camry won’t idle after battery change\cleaning of terminals. RenoJim 5th & 6th Generation (2002-2006 & 2007-2011) 0 08-18-2005 08:13 PM
RAV4 rims for 2002 Camry LE!! camry2002 5th & 6th Generation (2002-2006 & 2007-2011) 3 07-22-2004 05:47 PM
fog lights for a 2002 Camry gokada 5th & 6th Generation (2002-2006 & 2007-2011) 2 04-06-2004 11:34 AM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 01:48 PM
