Broken Wheel Stud. Now What? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2006, 02:13 AM   #1 (permalink)
Frank20's Avatar
View Frank20's Photo Gallery
Gen5 Broken Wheel Stud. Now What?
Well I finally got around to painting my brake calipers and drums this weekend. To do so i obviously needed to remove the wheels. In the process of removing the wheels 2 studs were broken when removing the lug nuts. One on each hub on both the front left and front right. I took the rears off without a problem. Im guessing the lug nuts were put on with an air gun and tightened too much which led to me breaking them when trying to get them off. So I basically have 4 lug nuts on both the front wheels. Should i get this fixed right away or can I take my time about it? Is it safe to drive as is? Anyone know how much I would be looking at to get them replaced?
CAR IS NOW SOLD
Frank20 is offline   Reply With Quote
Old 07-31-2006, 02:20 AM   #2 (permalink)
View DBIGMAC1's Photo Gallery
I would replace them right away, the bolt pattern spreads the load over all 5 bolts, the front of the car needs all 5, if it were the back you could get away with 4, not the front.
'07 Camry LE 2.4L Silver
'95 Camry LE 2.2L Gold
DBIGMAC1 is offline   Reply With Quote
Old 07-31-2006, 02:22 AM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
regardless- get them fixed as soon a possible!
HaHa
Old 07-31-2006, 02:55 AM   #4 (permalink)
View toyomoho's Photo Gallery
It should not cost that much. The job can be done with the hub on the car. You might a call tire shop; they must have seen a few broken hub bolts in their time. You could do it yourself if you had tool to press out the broken bolt. Check the posts below.
1997 Toyota Tercel - Broken Stud
broke a wheel stud
Old 07-31-2006, 10:15 AM   #5 (permalink)
Toyota Hemi
camryfour's Avatar
View camryfour's Photo Gallery
I had a stripped one on the front that I replaced on my gen 2. I just banged it out with the hammer and went to Autozone and bought a replacement. I just got the torque wrench and torqued the sucker down pretty good. It costed me about $2 for it.
camryfour is offline   Reply With Quote
Old 07-31-2006, 10:55 AM   #6 (permalink)
Gameroom cash: $101605
View kenny1773's Photo Gallery
I replaced several of them on my old gen 3 (stupid tire shop jacked up 4 of them on the same visit for me)
It is easy to do, take the tire off, spin the hub around until the stud it at the take out point (you will see a notch to allow it to pass in one area) then tap it out gently with a hammer, put the new one in and tighten a nut on it to pull it into place
I would recommend that you buy them from some place like NAPA - toyota charges about $10 per stud retail price.
**NOTE - buy new lug nuts to go on the new studs as well, you will regret it if you don't
kenny1773 is offline   Reply With Quote
Old 07-31-2006, 01:28 PM   #7 (permalink)
View marc780's Photo Gallery
I believe they are not threaded, they are held in by splines. So you can just soak em with wd-40 or whatever and beat em out.
no worries, pound the new ones in best you can and tightening the lugs will do the rest.
Old 07-31-2006, 10:47 PM   #8 (permalink)
As marc780 states, the bolts have a spine that presses into the hole. Be gentle with the hammer, there is a bearing inside the hub.
New CE - Bracket broken in wheel well Pingu Archived Corolla threads 3 03-02-2012 01:06 AM
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
1997 Toyota Tercel - Broken Stud Nallan Tercel, Paseo, Starlet, and Sera Forum 26 11-08-2005 12:10 PM
broke a wheel stud robbie8586 Archived Corolla threads 4 11-09-2003 09:48 PM
